Axxis Ultimates Squealing! Help!
Old Nov 8, 2006 | 06:26 PM
birjuh's Avatar
7th Gear
Unhappy Axxis Ultimates Squealing! Help!
Ok guys I decided to replace my front pads with axxis ultimates since they were almost close to being done. I kept my stock rotors since they were still good too. But right after leaving the shop I kept hearing a squeal whenever I was braking between 0 and 25 mph. It's the most annoying thing. So I waited about 2 weeks to see if it would go away. It was still there so I took it back. They guy noted that I had 'heat lines' on my rotors and that I probably bought cheap pads since there was so much brake dust (compared to my rear stock pads). So what should I do? My car sounds like a piece of sh** whenever I'm stopping-and I do a lot of it-I'm in the city. Thanks in advance!
Old Nov 8, 2006 | 06:53 PM
aaronng's Avatar
Driver/Detailer
Axxis Ultimates squeal. Either use another type of pad, or add on anti-squeal coating on the back of the pads.
Old Nov 8, 2006 | 07:56 PM
TSX007's Avatar
yeah I had them too and they squealed... very annoying. I changed them recently. My new pads don't squeal at all. Axxis was a disappointment.
Old Nov 11, 2006 | 06:21 PM
Rocket_man's Avatar
Summer is Coming
I pu Axxis Deluxe Plus on my last car and not a bit of squeal. You really need to be generous with the anti-squeal compound. The OEM pads squealed like heck. Did you use anti-squeal? Did you get it in the right places??
Old Nov 11, 2006 | 10:48 PM
birjuh's Avatar
7th Gear
I haven't put on any anti-squeal yet. You'd think that axxis would have fixed this by now...
Old Nov 11, 2006 | 11:24 PM
Switch's Avatar
Any of your more aggressive pads will squeal. Like said early, either suck it up or pick another pad
Old Nov 12, 2006 | 12:30 AM
aaronng's Avatar
Driver/Detailer
Axxis Ultimates are more aggressive than the Deluxe Plus, that's why they don't squeal on yours. But he needs anti-squeal for sure, and even that might not get rid of all of it.
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
2012wagon
Sep 29, 2015 04:21 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
Sep 14, 2015 03:16 PM
