Aux Adapter Wont Recognize
Hey Guys
I Just Bought The Blitzsafe Adapter For The Navi
I Tried Installing It But When I Go To Hit The Cd/aux Button I Dont Get Any Sound All I Get Is The Cd
Any One Have This Problem? I Was Reading On The Blitzsafe Web Page That Some Accords Are Not Picking Up The Adapter Is This True??
Please Let Me Know Thanks
Rep'n Taxbrain.com
Are you sure you're gonna be able handle such a diffcult intsall?
man...I remember how you did they non-navi-->navi install! How's the Navi system running for you nowdays?
Did you try turning the ignition off and back on?
![J/K](https://acurazine.com/forums/images/smilies/jk.gif)
yeah man tried turning the switch couple times and nutting
thats y im wondering whats up
welli hope i can over come this task lol
anyways if any one is having issues let me know thanks
When I install my Blitzsafe, first it did not regonized. I took the thing out and plug it back in again and this time I am able to switch to CD-C. I guess it is just a lose connector. You need to insert it until you hear a click.
If you still have problem, try to turn off and start the car again. This happen to me about a week ago in the morning. Once I start the car again, I can switch to CD-C
Rep'n Taxbrain.com
Originally Posted by ILoveMyHonda
I'm sorry I'm a bit of a noob in this area
what exactly are we talking about in this thread?
Sounds intrersting, whats a SNHOND3 and Blitzsafe Adapter![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
I dont mean to thread hijack but since we're talking about the Aux adapter, if I installed something into it, would I lose access to the factory CD player? Or does the CD/Aux button have two input sources... and you just simply toggle between the two using the same button?
I install the Blitzsafe and I still have access to my CD player. Just press the CD/Aux button second time and it will switch to CD-C. Press it again and it go back to the CD.
The head unit is not that difficult to get to. The "CD Holder" is just a easy pull to take out. Then you should be able to reach the connector (since it is at the bottom of the radio/Nav unit)
Rep'n Taxbrain.com
It's really easy to get to. Just tape up interior on the sides of the storage bin with painters tape or masking tape and then pull the storage bin out. Using a mirror, or even a CD. You can look right up, and you'll see it there.
If you have a 2005+ TSX though, you won't have an extra AUX input though. The factory XM is plugged into that port. You can still add another audio source, but you'll have to get an audio switcher to do this and tap into the XM audio lines.
i bought the blitzsafe aux adapter from logjam and it did not work properly. i bet if you unplug the navi bypass, the input adapter will work perfectly. the problem you have is when you plug in the bypass the adapter will not work. i sent my original back to logjam and they sent me a replacement. the replacement adapter had the same problem. i then asked logjam to send me the PIE adapter with the needed cable, and it is working perfectly. the PIE equivalent with the appropriate cable is forty dollars more than the blitzsafe adapter, but it works.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
