Aux Adapter Wont Recognize
Old Feb 15, 2005 | 10:44 PM
flopez82's Avatar
Hey Guys
I Just Bought The Blitzsafe Adapter For The Navi
I Tried Installing It But When I Go To Hit The Cd/aux Button I Dont Get Any Sound All I Get Is The Cd
Any One Have This Problem? I Was Reading On The Blitzsafe Web Page That Some Accords Are Not Picking Up The Adapter Is This True??
Please Let Me Know Thanks
Old Feb 15, 2005 | 11:36 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Are you sure you're gonna be able handle such a diffcult intsall? man...I remember how you did they non-navi-->navi install! How's the Navi system running for you nowdays?
Did you try turning the ignition off and back on?
Old Feb 15, 2005 | 11:51 PM
flopez82's Avatar
yeah man tried turning the switch couple times and nutting
thats y im wondering whats up
welli hope i can over come this task lol
anyways if any one is having issues let me know thanks
Old Sep 16, 2005 | 07:26 PM
halemeister's Avatar
Did you get this figured out????? I am having the same issue. Thansk.
Old Sep 16, 2005 | 11:09 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Yep...he figured it out. It ended up being a bad SNHOND3/Blitzsafe adapter. He had to send it back through warranty and get another one.
Old Sep 17, 2005 | 08:48 PM
irshpharoh's Avatar
when i got my SNHOND3 it didnt work at first then i unplugged the battery for 30 sec. and reset the radio.
Old Sep 18, 2005 | 02:11 PM
swong's Avatar
When I install my Blitzsafe, first it did not regonized. I took the thing out and plug it back in again and this time I am able to switch to CD-C. I guess it is just a lose connector. You need to insert it until you hear a click.
If you still have problem, try to turn off and start the car again. This happen to me about a week ago in the morning. Once I start the car again, I can switch to CD-C
Old Sep 19, 2005 | 03:19 PM
ILoveMyHonda's Avatar
17781708
I'm sorry I'm a bit of a noob in this area
what exactly are we talking about in this thread?
Sounds intrersting, whats a SNHOND3 and Blitzsafe Adapter
Old Sep 19, 2005 | 03:55 PM
Tsx536's Avatar
Rep'n Taxbrain.com
The SNHOND3/Blitzsafe are adapters that convert the AUX or auxilary input of the factory HU into RCA inputs. This allows you to plug anything in that has RCA outputs. The AUX input is normally used for CD changes, but these interfaces emulate the CD changer and provide you with RCA inputs to plug your Ipod/mp3 player, DVD player, etc.
Old Sep 19, 2005 | 05:56 PM
17781708
Sweet thats good to know thanks TSX536
So where do I find this connection on the HU.....do I have to pull it out and get behind it or is it easilly accesible
Old Sep 19, 2005 | 08:21 PM
tekn0mage's Avatar
I dont mean to thread hijack but since we're talking about the Aux adapter, if I installed something into it, would I lose access to the factory CD player? Or does the CD/Aux button have two input sources... and you just simply toggle between the two using the same button?
Old Sep 20, 2005 | 12:49 PM
swong's Avatar
I install the Blitzsafe and I still have access to my CD player. Just press the CD/Aux button second time and it will switch to CD-C. Press it again and it go back to the CD.
The head unit is not that difficult to get to. The "CD Holder" is just a easy pull to take out. Then you should be able to reach the connector (since it is at the bottom of the radio/Nav unit)
Old Sep 20, 2005 | 12:55 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Just like SWong said, You toggle between the 2 with the same button. So you don't lose the 6 disc changer.
It's really easy to get to. Just tape up interior on the sides of the storage bin with painters tape or masking tape and then pull the storage bin out. Using a mirror, or even a CD. You can look right up, and you'll see it there.
If you have a 2005+ TSX though, you won't have an extra AUX input though. The factory XM is plugged into that port. You can still add another audio source, but you'll have to get an audio switcher to do this and tap into the XM audio lines.
Old Sep 20, 2005 | 03:45 PM
McNuts's Avatar
i bought the blitzsafe aux adapter from logjam and it did not work properly. i bet if you unplug the navi bypass, the input adapter will work perfectly. the problem you have is when you plug in the bypass the adapter will not work. i sent my original back to logjam and they sent me a replacement. the replacement adapter had the same problem. i then asked logjam to send me the PIE adapter with the needed cable, and it is working perfectly. the PIE equivalent with the appropriate cable is forty dollars more than the blitzsafe adapter, but it works.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
ceb
ILX
Sep 27, 2015 10:56 AM
navtool.com
Sep 25, 2015 05:15 PM
