Automatic front engine mount in manual car?
Old Sep 26, 2014 | 09:09 AM
Tangoman's Avatar
Okay, so I now have a crappy aftermarket front engine mount.
It's stiff, which is okay, but for winter I will want to go back to a softer OEM style mount.
So, I see that the manual cars come with a vacuum assisted front mount.
P/N: 50830SEAE14
I see that the automatic cars come with a hydraulic mount, is it also vacuum assisted? Or just hydraulic...
P/N: 50830SDAA04
My question is, has anyone with a manual car switched to a mount for the automatic car and if so, what was the difference in feel? Is it vacuum assisted as well?
Right now my vacuum line is plugged because my aftermarket mount is just rubber without vacuum assist. I would normally just buy the OEM manual mount and be done, but I'm too curious
Old Sep 26, 2014 | 10:03 AM
TexasHonda's Avatar
The difference is mechanical; different bolt positions and mounting details for different transmissions. See page 5.17 of FSM.
good luck
Old Sep 26, 2014 | 12:23 PM
Tangoman's Avatar
I thought the front engine mount wouldn't matter depending on transmission. I thought only the transmission mounts would change.
So, on advance auto parts for instance, it says the same mount can be used on either transmission.
Beck/Arnley Engine Mount 104-1887: Upgrade with the best Engine Mount at Advance Auto Parts
Part No. 104-1887 Warranty
Be the first to write a review | View Customer Q&A
Product Application(s):
2004 Acura TSX
Front; Automatic Trans.; Hydraulic ...more
$146.99
Exact Fit for your 2004 Acura TSX
Engineered to manage engine torque and drive line alignment. Direct OE replacement. Premium materials and construction effectively dampens vibration and noise.
2004 Acura TSX
Front; Standard Trans.; Hydraulic
So they're both hydraulic and vacuum assist? Still confused.
Old Sep 26, 2014 | 07:18 PM
TexasHonda's Avatar
My mistake! I was looking at info on rear mounts. Front mount appears to be the same for both auto and manual.
good luck
Old Sep 27, 2014 | 01:14 PM
Tangoman's Avatar
good luck
Okay. Thanks. I bought the Beck/Arnley part and we'll see how it goes. Interesting that the manual/automatic mounts are different part numbers and one is much more $ than the other. We'll see how this goes.
Amazon had it for only 86 bucks shipped (prime). Still Hydraulic and still vacuum assisted. Should be pretty good then.
Thanks!
Old Oct 1, 2014 | 08:40 AM
TexasHonda's Avatar
These mounts have liquid damping that is mobilized when vacuum is applied to the mount. A vacuum actuator turns a valve opening the liquid to achieve active liquid damping. Vacuum only actuates the small valve in the mount.
Active damping only occurs at idle.
good luck
Old Oct 2, 2014 | 08:35 PM
Tangoman's Avatar
Yea, that is my understanding as well. The vacuum is pulled at idle and the mount softens up to help isolate the lower engine frequencies, since they'd transmit into the cabin.
Old Oct 21, 2014 | 10:33 PM
Tangoman's Avatar
Update in case anyone cares.
I bought the Beck/Arnley front mount. I still have a cheap chinese rear mount. Front mount softened up the car back to stock at idle, but under load/accel it is still sitffer than normal (because of the rear mount doing the work).
Overall, I'm happy with it. Car feels back to normal enough for me. 6MT
peti1212
ILX
22
Jan 5, 2022 05:14 PM
james357
Feb 13, 2016 02:37 PM
Mike Bertram
Sep 10, 2015 09:27 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
