Any Oil consumers out there yet??
Old Aug 27, 2003 | 07:39 PM
Champ's Avatar
I'm a beer consumer and my RSX type S is an oil consumer
I will go through 2 quarts between oil changes (5K miles)
My old CRX Si never did this.
It's wierd, some K20 motors do this and some dont. Some do it so bad that folks have had their blocks replaced under warrantee. Has the K24 showed any signs of being an Oil consumer too anyone??
Just to be safe, make sure you all check your oil levels between oil changes so you know how your car is doing. alot of folks blow it off thinking its a new car -why bother, next thing you know your having to replace your motor
Old Aug 27, 2003 | 08:42 PM
majormojo's Avatar
such a dirty birdy
I check all the under-hood fluids at every gas fill up. Filled the tank on the TSX for the first time last night and the oil level was BELOW the add mark. I topped it up, but I'm really annoyed that 1) the dealer sent it out that way and 2) I didn't check it myself when I picked it up. I just ASSumed it was OK.
Old Aug 28, 2003 | 05:58 AM
sauceman's Avatar
Moderator Alumnus
Mine took a quart for the first 4000km, then nothing more.
Old Aug 28, 2003 | 06:08 AM
moda_way's Avatar
Checked my oil prior to my 3K oil change (yes, controversial, but I use only synthetic) and my engine hadn't consumed anything.
Old Aug 28, 2003 | 01:15 PM
TinkySD's Avatar
Audi Driving Snob
mine used maybe half a quarter to the first oil chang.e in the 1500 mile ssince nada.
Old Aug 28, 2003 | 04:41 PM
Weck's Avatar
That blowed up real good!
I had to add a half quart (1/2 litre for us Canuks) at 2,400 miles. I expected this since I've pushed the car hard for 2 weeks. I keep a close eye on the level every week.
This is normal for a high revving 4 cyl engine during a proper break-in period.
Old Aug 29, 2003 | 07:19 PM
ssm_tsx's Avatar
I've got 3600 miles and I've added almost a quart.
Old Aug 30, 2003 | 10:37 PM
txtsx's Avatar
Mine's a bit low at 3500 miles. I broke it in hard and it drive it a bit aggressively.
Old Sep 9, 2003 | 09:11 PM
carlucc's Avatar
Thumbs up oil consumers
I drive a GS-R, and yes the 4 cylinder V-tecs burn a little oil. I am not surprised the TSX burns a little too. Bu tI would be concerned if its that new and it burns oil. Check it in the morning when its cold, and then check it after a start. Compare the difference. Don't forget the first 6000 km Honda puts some different type of oil in there to break it in.
Old Sep 10, 2003 | 01:41 PM
CopperTop's Avatar
Re: oil consumers
Very true. You can expect to add up to a quart between the delivery and your first scheduled maintanence.
Old Dec 2, 2003 | 11:23 AM
toddstuh's Avatar
I've located the source of my high oil consumption. It's an oil leak !
I checked my oil at around 600 miles , at my second fill up and found it almost a quart low. I added about half a quart to bring it up a bit. I didn't want to over fill it.
Upon checking underneath the car , it turns out the plastic cover that is used to access the drain plug was almost dripping with oil.
The top of the engine is brand new clean.
I checked the drain plug for snugness as well as the filter which was also ok. I dried them both off and the next time I drove it the oil pan was wet again. I suspect its the oil pan gasket.
It appears to be on the back of the engine (firewall side) more towards the passenger side.
What else is down that low ? The oil sensor ? any seals ?
I haven't been really pushing the car either. I just started revving it over 5K when i hit about 800 miles. prior to that 3-4K was about the max.
haven't contacted the dealer...it snowed today so I'm driving my Jeep w/ 4 Blizzaks(which doesn't leak BTW) !!!
Old Dec 2, 2003 | 11:27 AM
moda_way's Avatar
I've got a little over 8200 miles and 2 oil changes already (3k and 7.5k). Took a 1k trip over the Thanksgiving holiday pushing 80mph most of the way and used about .25 qt. That is pretty normal in my mind for sustained traveling.
Under my normal driving patterns (30 miles round trip to work) I don't loose anything.
Old Dec 2, 2003 | 11:45 AM
vwong's Avatar
n00b
For those who claim that your car burns oil, how is your driving style? Do you get into VTEC (high rpm/redline) more than 50% of the time when you drive? If so, you found your problem. Both my Prelude and Integra burn oil, I had to put in at least 1 quart of oil in between oil changes. I'm not complaining because I know my driving style. Plus I do auto-x both cars a lot (well, at least in 2002). :P
Old Dec 3, 2003 | 10:31 AM
DEVO's Avatar
My GS-R goes through 1 1/2 quarts for every 5000miles. On the other end of the spectrum... i add no oil in my hybrid for every 5000 miles traveled. In fact I can't even see a change on the dip stick (same level every time i check it). I know it's impossible to not burn any oil but this comes close.
Old Dec 13, 2003 | 06:54 PM
RA121724's Avatar
never lost a drop
Old Dec 14, 2003 | 07:40 AM
Gpump's Avatar
You want me to break it?
I just changed my oil at 5000 miles, no apparent oil consumption. I never added anything, hope it doesn't start now that I'm using Mobil 1...
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Thuneau
Oct 3, 2015 04:19 PM
jubikej
1G RDX Problems & Fixes
Sep 30, 2015 01:13 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
