ABS problem???
Old Aug 28, 2004 | 02:01 PM
euroStyle's Avatar
ABS problem???
while braking, if i go over a small pot hole or a bump, or uneven pavement, i think the abs engages. the brake pedal shakes. i dont think the rotors are warped, the doesnt shake while slowing down on high speeds or when i lightly press the brakes on high speeds.
Old Aug 28, 2004 | 02:13 PM
Lung Fu Mo Shi's Avatar
Registered AssHat
Yes, it is the ABS engaging. Effecively your wheel hopped or slipped a bit making the onboard ABS sensor thinking the wheel is slipping. Thus it turns on the ABS.
Bottom line, it has low tolerance, but it is normal operation
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
