6spd Transmission Problems
Has anyone had any problems with their 6spd Transmission in the TSX. I bought the car this past June and after driving it 3500km from Toronto - Nova Scotia and back, the main shaft bearing went. My local dealer torn open the transmission and replaced a few bearings and a ton of gaskets. Ever since this fix, my shifting between 1 & 2 has been very notchy. Since this happened so quickley, I haven't been able to enjoy the 6spd that everyone is talking about. The shifting just doesn't feel right. I suppose I should test drive another TSX at a dealer to compare.....I might be supprised.
At my last oil change (20,000) I got my tranny fluid changed to this stuff called Redline. It's synthetic. I had been noticing notchiness for the last 2000 miles or so. They said my tranny fluid had gone bad, guess it happens around 15,000. Maybe you should try changing fluid. It made a world of difference for me. Now I love shifting again!
C'mon, man! Row yer own.
I have read elsewhere on AZ that the Acura's manual tranny oil is fairly specialized -- not exotic, just specialized. Is the Redline a legitimate alternative to the Honda MT oil? How does one know? In other words, what are the specs on the Honda oil -- like, the engine oil is 5W-30 so you can use any brand of that viscosity. How do you compare one MT oil to another to see that you're using the right stuff?
Master Graphic Artist
Hmm I've been noticing slight notchiness sometimes when I shift into first gear. I've only noticed it recently. Sometimes it doesn't click in so I have to pull it back and push it in again.. or force it in. This also has been the case with my reverse gear. Ever since I bought my car at times when I throw it in reverse, while my car is not moving, it either won't go straight in or I hear a NASTY gear grind and have to pull it out and engage it again.
Have camera, will travel
Something is amiss here.
yeah I was kinda surprised it went bad too. It made a huge difference when I changed though. One factor could be that I do love to row through my gears and I downshift through the gears at every stop. Do you think that downshifting would wear out the fluid faster if I downshift through every gear except 1st?
^^^I'd say so. Downshifting through the gears at every stop is a little much I'd think. You know the old adage, replacing brakes is cheaper than replacing a tranny.
Downshifting during spirited driving, yes, downshifting at every stop, no.
on any given drive, i'd probably downshift about 30% of the time to a complete stop.
Yeah I guess I probably shouldn't always downshift, but I love doing it. My dad, who had his first MT Legend for 7 years and then his second MT Legend for 8 years, taught me to do it and he's never had to replace a clutch. Maybe I'll try to break the habit though. Suppose it could save my synchros which might be worth it.
Originally Posted by Power1Pete
Proper downshifting to a stop (w/o going to 1st gear) WILL save your transmission wear out prematurely.
But the transmission will suffer less wear if you don't downshift at all when coming to a stop, relying only on the brakes.
yeah how can downshifting save my tranny?
No lube = bad for transmission.
Therefore, proper downshifting (rev match) is the best way to slow down.
In addition, some states actually outlaw coasting in neutral (i.e. New York).
I don't know about not getting any lubrication in neutral -- doesn't sound right but I don't have that much expertise with manual transmissions. What I have found, though, is that leaving the car in gear (clutch out) until 12-15 mph (while braking coming to a stoplight, say) and depressing the clutch at that point provides some engine braking. I've had to get used to it as my habit was to just press the clutch when I started braking, and then rowing through the gears (except 1st) with the clutch in. Don't ask me where I got this habit, I don't know. The engine doesn't buck or stammer or anything at 15 mph and I think it's much better for the tranny, sychros, and (a little) the brakes.
this is what i do. up until the rpm's hit below 1000, i'll leave it in gear. once it touches < 1000 rpm's, pop it in neutral...
maybe if i wasn't as lazy, i'd probably be downshifting 24/7 too...
I read somewhere on this forum that when downshifting you aren't using any extra gas. Guess I'll ask my service guy about it when I go in on tuesday. Probably won't know that much, but it's always worth a shot.
I would say it could be because of the cold weather. I park my car outside and it usually takes my car a few minutes before the transmission warms up and the synchros will really work smoothly. When I park inside or I warm up the car first there isn't usually much of an issue. If your car is getting up near 15,000miles I would say see about changing your tranmission fluid to synthetic redline.
I really wonder what the deal is, can anyone explain why when I am at a complete stop, I press the clutch all the way, and attempt to put my car in reverse it sometimes gives a nasty gear grind and won't go in? This happened from day one I got my car and is still happening at 19k miles. It doesn't happen often, I'd say maybe 10% of the time.
Also, is changing the tranny fliud straightforward and simple?
iVTEC no koe
Hmm, maybe warming up my car is the case. I do recall this happening during the warm summer with my reverse gear.
I got my dealer to change my transmission fluid so I don't know if it is very difficult or not. It seemed like they changed it in about 5 minutes.
I can't roll backwards and then put it in reverse. I have to come to a complete stop.
Registered Abuser
Originally Posted by HoRRo
I've never had the reverse gear grind when at complete stop, but mine will grind 100% if my car is rolling backwards and I attempt to put it into reverse. Anyone else get this? I was able to roll and shift into reverse in my bro's civic, but not my TSX.
To avoid doing damage to your tranny, make sure you are at a full stop before attempting to engage reverse, regardless of if you have the clutch in or not.
Driver/Detailer
But never a grind in reverse when stationary. This points to your clutch plate not fully disengaging.
Driver/Detailer
Someone stole "My Garage"
One way to avoid the reverse gear grind is to go from neutral, to 1st, and then directly to reverse. This trick worked on my 1991 Integra like magic (never failed) and it's habit that I go 1st-reverse now with the TSX, and I've never had a grind in reverse with this car, ever.
BoricuaTL
04-08-2016 01:08 PM
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
