2005 tsx starting problems
Old Apr 4, 2012 | 01:42 AM
Xinger's Avatar
Ok so hear goes, my engine light had been on for months because, got checked at acura and was told it was a bad primary 02 sensor, replaced it, light went out for a day and came back on, the first time I fill the car with gas afterwards the car cranked over and over and barely started. It did start after a few tries, replaced spark plugs a few days later, filled up with gas again and had the same issue but much worst and acually had to press gas pedal to the floor to get the engine to catch. Once started it didnt want to keep running either for the first 30 sec but after that it would be fine. I didn' t have any probs previous to changing 02 sensor other than the check engine light saying the sensor was bad. I havnt brought the car back to acura to put back on the com but was hoping someone had similar issues, could it be coincidence or unrelated to the 02 sensor... Thanks
Don
Old Apr 4, 2012 | 05:21 AM
ALPH4's Avatar
I had a similar problem on my old 04 rsx, turned out to be the starter motor that needed replacing
Old Apr 4, 2012 | 07:13 PM
Xinger's Avatar
My car cranks over just fine, but seems to have trouble starting when refilling on gas, could it be a faulty gas cap, could that couse those sort of problems?
Old Oct 4, 2012 | 01:14 PM
jennj24's Avatar
I'm having the same problem w/my TSX as Xinger....wondering if you could advise as to what the problem was?
Thanks,
Jen
Old Oct 4, 2012 | 10:03 PM
RA032025's Avatar
in the 24th and a half...
Perhaps the sensor was OK but something was fouling it. Now the new sensor is getting fouled too. Perhaps at start-up?
Second thought, wrong sensor either used or replaced?
cycdaniel
Dec 17, 2019 10:58 AM
handsom-hustla
Nov 13, 2015 05:04 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
jordanboi
Sep 5, 2015 01:33 AM
brjones9
Sep 3, 2015 07:30 PM
