2005- ABS,VSA, (!) light on after a flat tire change
Old Jun 26, 2011 | 01:53 AM
suchit333's Avatar
4th Gear
Hi,
I had a flat tire this morning. I may have driven more then a mile with a flat tire unknowingly. The entire tire got cut as shown in the pic. I replaced it with a spare, I saw ABS, VSA and (!) lights being on. Later this evening I replaced it with a new factory recommended Michelin tire, but the ABS, VSA and (!) lights are still on even after driving 8-10 miles with the new tires.
I don't know what the problem is. I never had any problems with my car until today. Can you please advice on what I should do.
Appreciate it.
Old Jun 26, 2011 | 05:54 AM
Simba91102's Avatar
Old Guy
First thing is you have to wash that wheel........ Seriously though, that tire is pretty trashed, and if the inside is as bad as the outside, you may have clipped the wiring harness that runs down to the wheel hub area for the ABS and skid control with the disintegrating tire.. You may not be able to see it without removing the wheel, but if you do that, just take a good look and you should be able to see the cable and where it connects to the sensor. It kind of runs down along with the brake line (don't confuse the two). Sorry, kind of hard to explain, but if you take a look, you should be able to figure out. I can't think of what else might be going on, so that's my theory.
Old Jun 28, 2011 | 08:22 PM
suchit333's Avatar
4th Gear
Thanks Simba,
This is going to cost me an arm and a leg to fix.
I spent $65 to diagnose the problem at the Acura dealership. The ABS sensor needs to be replaced. The wiring is ripped off. I'm not totally sure if it can be repaired, but as expected the dealership guy said its repairable.
Now I'm paying $135 for the part $109 to install. Total of $310. Such a costly error.
Not sure if any regular car service place can install the sensors??
This is the second time I'm losing a tire like this after going flat. I can't feel any difference in driving when the tire goes flat until it tire gets torn, can't hear any noise. How do you know when the tire goes flat while driving?
Old Jun 30, 2011 | 03:12 PM
littlebo's Avatar
Hey bro , really dunno why dont you feel flat tire . Even if er tire is a lil bit flatter then others er car will slightly turn left or right when you take ur hands off turning wheel.
mada51589
Jan 9, 2025 04:40 PM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Stu2414
Aug 30, 2015 07:30 PM
