2004 TSX Door Lock Problems
Old Nov 11, 2007 | 01:44 PM
99NCAA's Avatar
Any one hear of any 04 TSX locking issues? My passenger side door will not lock or unlock with the key fob or internal door lock switch?
Easy fix?
Old Nov 11, 2007 | 02:25 PM
Simba91102's Avatar
Old Guy
Easy fix?
Had this problem with an Accord years ago and it's an easy fix for an Acura technician; don't know about do it yourself. You should get plenty of response here though, as I think that along with a number of other things, door lock problems are not that uncommon with the 04's (as represented here anyway).
Old Dec 9, 2007 | 12:14 PM
Tech7427's Avatar
Under your Acura...
door lock actuator.
they will usually goodwill it if its over warranty and youre a good customer.
i wouldnt recommend it to a novice.
especially removing the latch screws in the door..bawhhaahha
air hammer ftw
Old Dec 12, 2007 | 04:56 PM
carbonatd's Avatar
Yes, 04 tsx, passenger side door is not working here iether.
carbonatd's Avatar
Just started actually. Last week
Old Dec 13, 2007 | 01:21 AM
human668's Avatar
Mine doesn't work also. Anyone know how much should I pay dealer to fix it?
Old Dec 13, 2007 | 10:40 AM
aznt1217's Avatar
Mine just started on my driver side door lol
Old Dec 13, 2007 | 12:06 PM
dom's Avatar
dom
Acura should release a fawkin TSB.
Old Dec 17, 2007 | 08:35 AM
CJaneDrive's Avatar
2016 RDX Advance Blk/Blk
2005 TSX has door lock problems, too
My front passenger-side door lock had this problem when my 2005 TSX was still under warranty. Then, 10K miles over-warranty, the driver-side door lock developed the problem. The dealership won't do a courtesy repair for me despite my best efforts and mentioning that numerous Acurazine members have experienced the same problem.
I would LOVE to do something organized to get Acura corporate to admit that they have a problem. Any advice as to how to get this started would be greatly appreciated.
Regards,
Jane
Old Dec 18, 2007 | 05:26 AM
99NCAA's Avatar
Regards,
Jane
Call Acura Customer Relations. They were more than hepful in my case.
Old Dec 18, 2007 | 05:28 AM
jmathew34's Avatar
i have this same problem too on my passenger side...
Old Dec 18, 2007 | 08:14 AM
krasyazian's Avatar
My driver side actuator lock seems to be failing...it's really slow locking/unlocking
Old Dec 19, 2007 | 12:59 PM
CJaneDrive's Avatar
Thanks for this advice. I'm going to do that. I'll keep you posted via this thread.
Old Dec 22, 2007 | 06:40 PM
iROK's Avatar
I gotta take it to the dealer too, my passanger side just stopped working.
Old Dec 22, 2007 | 09:57 PM
Power1Pete's Avatar
TSX Addict
I changed the actuator myself. It was PITA.
If the dealer won't give you a break, they will charge you $200 for parts and labor. Good luck.
Old Dec 23, 2007 | 02:10 AM
human668's Avatar
I asked Weir Canyon Acura CA. If I provide the part, they will charge $165 for labor.
Old Dec 26, 2007 | 09:03 AM
CJaneDrive's Avatar
I called the phone number for Client Services that I found after hunting around on Acura.com. I spoke to a representative who informed me that opening a case and assigning it to a Case Manager for consideration for a courtesy repair requires my obtaining a diagnosis of the problem from my Acura dealership. Of course, there's a charge for that, and it costs me my time - time that could be spend actually getting the lock repaired instead of waiting for the dealership to "diagnose" the problem, which I know to be the actuator since this has happened to me before! Now, I get why this policy is in place, but I can also see the writing on the wall and have decided to just pay for my mechanic (not the Aucra dealership) to replace the actuator.
Old Dec 26, 2007 | 09:07 AM
CJaneDrive's Avatar
That's a lousy deal since the actuator costs less than $20 according to a couple of OEM parts Websites that I checked.
Old Dec 26, 2007 | 01:15 PM
human668's Avatar
yea, and I think it will just take an hour for their mechanic to work on it. Charging $165/hr does make sense in my brain.
How much do you pay your mechanic to fix it?
Old Dec 26, 2007 | 07:47 PM
2006CGPTSX's Avatar
06 TSX had the problem with both front doors, dealer repaired under warranty. Took about 2 hours. Seemed to work find after that, but I only kept it a few more months and was bit with the new car bug. Traded in for a 08 RDX.
Old Dec 27, 2007 | 11:22 AM
CJaneDrive's Avatar
I'll let you know how much via this thread when I know - I haven't even gotten a quote yet and probably won't for a couple more weeks.
Old Dec 28, 2007 | 07:53 AM
npolite's Avatar
Honda needs to step up to the plate and cover these as a recall. These should not be failing on a 4 year old car. My 95 Integra has 119k miles on it and have never had to replace these. I've taken door panels off before so it isn't a big deal for me, but I too would be pissed if I had to do this on a 4 year old car.
Old Dec 28, 2007 | 09:01 AM
dwest1023's Avatar
Sometimes I think Honda has these parts fail on purpose. This way, you get frustrated, buy another Acura/Honda and they get a nice used car to make more money. So far I have seen, compressor failures and these door lock issues. Not to mention all the transmission issues. All these parts have been made for years, so why can't Honda find a good supplier of these parts? I think they don't want to.
Old Dec 29, 2007 | 09:29 PM
npolite's Avatar
Are compressors another common issue with the TSX? I haven't heard of any problems on the Honda line before.
Old Dec 30, 2007 | 05:29 AM
dwest1023's Avatar
They have been failing on the 04's and I have read many more failures on the honda forums.
Old Feb 10, 2018 | 04:42 PM
SFO2004TSX's Avatar
5th Gear
Both lock and power window switch???
I was told that I had to replace both the door lock actuator switch AND the power window switch. Seems odd to me. He (mechanic) said the two were in series and window won't work with out door lock switch
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
ahsm
Sep 9, 2015 08:35 AM
