07 TSX Electrical Problem - HFL?
Old Mar 21, 2014 | 12:56 PM
EosPhotog's Avatar
I have a 2007 TSX and have been dealing with a strange electrical issue.
Three weeks ago I went out to lunch and on the way back could not start the car. Display would flicker/click. Jumped the car, and it started. Drove to Autozone and battery and alternator both passed their load test. After that car started fine, no problems.
Then this morning I have a little bit of a slow crank, but not alarmingly so. 20 minutes later I'm at a stop light and strange things happen in the span of about a minute:
- Passenger air bad indicator/fault turns on and off and flickers
- Seat belt indicator then starts going on an off
- A cascade of other alerts start coming up - TPMS, etc.
- The display lights start to flicker and engine strains a little
Light turns green and I take off, changing course to go to the dealership to figure this out. All the alerts immediately stop when I accelerate and car is running fine.
5 minutes later, about 10 minutes out from the dealer I get a "Check Charging System" and a red battery alert. Aha! Alternator? Maybe? Would make sense I'd think.
I pull into the dealership and of course, the check charging system alert clears. I list all of my symptoms and the service agent tries to start my car but doesn't turn over. "Its the battery" he says. "No, its more than that" I say. So off they go to do a "draw test".
A couple of hours later I get a call - they narrowed it down to a faulty HFL. Apparently the module is pulling too much power. They want nearly $1500 to fix.
... And apparently someone's boat payment is due...
Right. So they're going to just disconnect it. Which is irritating but better than shelling out $1500.
So question is: Does a faulty HFL which puts a high draw on the electrical system account for the behavior I saw? I'm struggling with this because I would think that if the alternator is running then while the car is on it shouldn't be a problem, but rater be a problem when the car is off. Alternator apparently checks out and nothing else seems to be a problem. Also I'd think if the draw was so much it brought down the 12V bus wouldn't it also blow a fuse?!?
What do people think. Faulty HFL? Disconnect and we're done? Or is that a red herring and there's another issue at play (can an alternator be intermittent?)
Old Mar 21, 2014 | 03:51 PM
TexasHonda's Avatar
Others have had similar problems w/ HFL draining battery.
Suggest pulling connector to HFL control unit under glove box and see if problem is resolved. If yes, the HFL is the culprit.
Used parts (car-part.com, ebay) are likely to provide lower cost replacement parts if you decide to replace.
good luck
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Fandango12
1/2G MDX (2001-2013)
Sep 20, 2015 05:25 PM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
brandnewcolony
Sep 12, 2015 10:39 AM
