'06 Computer Glitches?
Old Feb 3, 2006 | 06:16 PM
Sojournin's Avatar
Out n about
I could be asking my dealer this, but I'm not sure if he can answer it so I'll throw it out to you guys. I picked up CGP 06 w/Nav last week...and I've been playing with it...even reading the manual I'm learning that there are some things in the manual that says I should be able to do, but I can't.
The MID (multi-information display) is supposed to recognize me when I use my key fob to unlock the car...and say "Welcome User 1" in the MID. The reason why this is important is because certain features are customizable to each user (i.e. how long the headlights stay on after I turn off the engine, how long the interior lights stay on afterwards, intermittent wipers association with the engine etc....) Well on my car, although the keyfob can unlock the doors and trunk, the MID doesn't seem to recognize it as User 1, so I am not able to get into the customization screen to make these adjustments.
The other thing I noticed is the Navi screen doesn't switch over to night time when my lights are turned on. It just stays bright for daytime driving. I have it set on Auto, but that doesn't seem to make a difference. I am able to manually switch them, but shouldn't Auto do this?
Any advice would be appreciated.
-Sojournin in Philly
Old Feb 3, 2006 | 06:20 PM
theone55699's Avatar
bring back to the dealership. its still under warrenty.
Old Feb 3, 2006 | 06:51 PM
Yui's Avatar
Yui
I had the same issue with the key fob. You need to link your key fob to your car to get the customized settings per keyfob. Check your manual on how to do this.
Old Feb 3, 2006 | 07:36 PM
helraiser's Avatar
press and hold the lock & unlock key till the red led on the keyfob flashes. done.
Old Feb 3, 2006 | 09:55 PM
lilballa's Avatar
tsx's4playinwith
yeah I had the same problem, but i eventually figured it out. You have to set your seat and then save it using the seat memo buttons 1 and 2. After that get your remote key and get in the car and hold down the lock and unlock but at the same time( red light will flash on the key). Then get out of the car lock it and then unlock it and get back in. When you turn on the car, it should say welcome driver 1 or 2
Old Feb 3, 2006 | 11:08 PM
PKG's Avatar
PKG
Navi system
I had the problem of the Navigation system not dimming on my 04 TSX, but it works fine on my 06 TSX.
Old Feb 3, 2006 | 11:53 PM
Sojournin's Avatar
Out n about
Ahh! That did the trick! Thanks
But the Nav is not dimming no matter what I do.
Old Feb 4, 2006 | 12:16 AM
Runt888's Avatar
If you have the interior lights turned all the way up (the left rotating switch that sticks out of the gauge area), then the nav will stay in day mode even with the lights on. Just turn it down at least one level.
Old Feb 4, 2006 | 07:48 AM
bigwilliestyle's Avatar
Old Feb 4, 2006 | 03:46 PM
narci's Avatar
Canuck
ding ding ding!
the man's right!
Old Feb 4, 2006 | 07:54 PM
Sojournin's Avatar
Out n about
YES!!! Thank you! Thank you!
Why can't Navi "ding" when it's time to make a turn? I kinda like that feature on some navs.
rockyboy
Aug 4, 2024 10:35 AM
Dec 7, 2020 05:39 PM
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
AcuraKidd
Sep 25, 2015 11:18 PM
