05 TSX 6M final drive assembly failure
Just FYI on this. Symptom was a thumping sound when the drivetrain was engaged -- not with clutch pedal in, and not in neutral. Thumping was timed with wheel rotation.
85K miles. Ring gear on final drive popped 3 teeth. My mechanic said the rest of the transmission is pristine, with no signs of fatigue, abuse, or grinding. Clutch in awesome shape.
No idea how this happened. He said that when he's seen it, it's from spinning both tires off of ice onto dry pavement, or a sharp turn with both wheels spinning. Neither of those happened, so I'm chalking it up to one minor QA issue somewhere in the alloy or similar.
Glad to have it back. $2650 out the door with tax, but this shop is awesome, and worth some $$ (Eagle Transmission in Austin, TX).
https://acurazine.com/forums/1g-tsx-problems-fixes-128/04-tsx-6mt-front-end-sound-clicking-through-gearshift-667479/
you can read my post starting post #26 about my experience....
justin7779
Dec 25, 2015 10:33 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
