04 TSX Knock Sensor P0325 will not go away!
Hello I have a 04 TSX with 127k miles that is throwing p0325. Originally thought it was going to be a simple fix by just replacing it but that hasn’t been the case. Originally put in a dualast replacement, code was still being thrown so went and got an OEM, code is still being thrown, replaced the wire from the sensor to the harness with a heat shrink but joint, once again still getting the code, went back and got a new pigtail and did things the right way by saughtering it in, and still haven’t been able to fix the issue.
with that I have also replaced the battery ground along with the ground that comes off the transmission mount. Brand new alternator, battery and starter done as well. Code was thrown before doing the starter so I don’t think anything was harmed there.
I’ve done absolutely everything I can think of and read just about every thread I can find on forums so please any realistic ideas or recommendations would be greatly appreciated.
2008 tsx following. same boat as well. Replaced sensor and bought new connector and wire. Was suggested to bypass the wire harness and connect straight to the plug. Code disappears after a time but comes back.
Where did you get your replacement sensor?
Is the P0325 code being cleared from the ECU after you did the remedial work? I can't speak to the need on an Acura, but many cars have to have this code cleared, or the code notification just repeats. It can be cleared with most OBD II readers or simply disconnecting the negative battery cable for about 10 minutes. Good info on the P0325 code at P0325 Code – Causes, Symptoms, and Fixes
Proper gas too can be a factor. I think the 2004 TSX requires 93 octane. If you are getting that, and from one particular station, try a different source. It wouldn't be the first time a station was attempting to rip off the consumer.
Good luck!
Good luck!
How does one differentiate a knock sensor code meaning something is wrong with the knock sensor circuitry vs. a knock sensor code meaning your sensor is working and detecting a knock condition? Is it possible you’re chasing the wrong root cause?
Some good content about the P0325 code at P0325 code
Curious have you replaced your alternator with a non oem? Recently started having issues with my speedometer and tachometer dropping to 0 and VSA light coming back on, both will come back after a second with the VSA light staying on.
Good luck!
Good luck!
Im on the west coast so 93 isn’t an option, highest I have and have been using is 91. I did do a Techron addative and drive thru the tank, I really didn’t see much of a difference to be honest maybe a couple more miles till E but it wasn’t night and day difference. I’ve been going back and forth between different Shell and Chevron stations so I can’t say I’ve gotten a bad tank of gas
At first I was disconnecting the battery for about 20-30 minutes and it would go away, sometimes I’d drive 1/4 mile and it would come back, sometimes I could do 20 minutes of city driving, 40 on the highway and think it’s gone for good, go home and the next time I turn it on within the 1/4 mile or so it’s back on. After a couple heartbreaks from dealing with that I picked up a obd2 reader that can clear codes as well as some live data. Even with that it’s still back on within no time.
Funny you say that, when I first had the codes read I saw the knock bank 1 and thought it was that without looking into it. The car still needed a cat and both O2 sensors plus a handful of other “Tune up” stuff so I ignored it till last figuring it could go away being a false knock, wasn’t till someone said “That’s not your engine possibly having knock, its the sensor” and I reread it and had a good laugh.
Figured to give driving the car a try and see if that would be able to get rid of it. After 560 miles in a week of city and highway driving with trying my hardest to follow the steps posted on here to get rid of a cel light it didn’t work for me at least.
The only thing on the car that’s not OEM is the alternator being a duralast but it’s reading at 14.33 so I want to hope that’s the issue but part of me doesn’t think it actually is causing any problems and not to throw more money at a OEM or even rebuilt OEM
elchapo
01-13-2020 02:20 AM
