Injen Intake -> short ram installed pics
Injen Intake -> short ram installed pics...**sound file added**
since no one has posted pics of what the injen cai installed the short ram mode looks like...
sound clip
right click save as (1mb)
sound clip
oh man I love that!!! I can wait. What kind of performance gains are you feeling with the SRI? I assume there really no down side to the SRI, as in no water being sucked in etc. Have you ran CAI with it to? is is an easy change?
virus7...i cant tell from the butt dyno, but i expect a few ponies from it. i havent tried the cai setup yet. havent had a chance to take the resonator out.
domn...check out this sound clip i made...its 2nd gear and pretty much wot to redline then shift to 3rd.
right click save as (1mb file)
ortiz...i got it through the gb at club tsx. u can find it online for about $200 shipped or so.
Originally posted by Lung Fu Mo Shi
I do have a question. Your Injen sticker on the 3" pipe attached to the throttle body...is that rated for engine temperatures or is it going to peel/discolor after time?
Originally posted by JTso
I hope you are ready to inject hot under hood air into your engine. A short ram without a heatshield around the filter will suck in incredible amount of hot air. The stock setup is more restrictive but at least it's cooler than a short ram. Also, the intake manifold is already pretty hot as it is sitting behind the the radiator fan. I would go with a CAI instead. Sure, it's more work but it's a better solution. It's a function over fashion thing...
The high temp mainly affects performance, which is counter productive of having the SRI without a heatshield. An OBD2 Honda ECU reduces fuel and retards timing when the IAT sensor detects high temp. The opposite is true when the intake temp is low.
when you have your injen setup short-ram is there enough clearance to use the injen heat shield?
here's another question: are there any gains over the stock setup if you ran the injen short-ram with a heat shield? or are you better off just leaving it stock?
cycdaniel
12-17-2019 10:58 AM
nanos
11-12-2015 08:41 PM
Abe_Froman
09-16-2015 01:27 PM
