Warning on Clutch Kit
Greetings!!
I just in the middle of changing my clutch at the acura shop. I receive a call today that the kit I installing cannot fit. My kit is Exedy #08806 and we found that it will not fit the oem flywheel
. I just bought the Exedy #HF02 flywheel to make it fit. The actual pressure plate is smaller that the oem. So I need to wait until monday to finish the install.
What can I expect when using a ligther flywheel??
I later found that Daikin just release the oem kit HCK1010.
I let you know the final chapter of this thing.
Thanks to all
. I just bought the Exedy #HF02 flywheel to make it fit. The actual pressure plate is smaller that the oem. So I need to wait until monday to finish the install. What can I expect when using a ligther flywheel??
Thanks to all
Sorry to bring back an old thread but I'd love to know a little more.
I am going to have to get a new clutch very soon
Is the Exedy #08806 comfortable yet still really grippy? I don't want my leg to fall off in traffic, but I'd also LOVE to put a clutch in that will LAST.
Any additional problems in the install process other than the flywheel issue?
Is the Exedy #08806 comfortable yet still really grippy? I don't want my leg to fall off in traffic, but I'd also LOVE to put a clutch in that will LAST.Any additional problems in the install process other than the flywheel issue?
Originally Posted by madmanmax3000
I've always been told its much easier to stall with a lightweight flywheel, did you stall at all after having it put on? any regrets?
kendroz,
Are you still happy with your exedy stage1 / lighweight flywheel setup? I am thinking about doing the same.
Any disadvantage at all? Is shifting still smooth and easy?
Any tips/recommendations?
My car is mostly stock, by theway.
Thanks!
Thanks!
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
