tsx performance question
Old Sep 27, 2004 | 01:11 AM
tsxhondatuner's Avatar
6 speed yo!
posted this question a while ago....but....
coming from an Integra to the tsx (6speed) ive noticed some differences.
first gear is a lot faster but when shifting from 1st to 2nd the rpms drop a considerable amount. im not sure if its just my car or what but i dont think this is right. everyone always tells me that my cars pretty fast blablabla so im like umm it ain't that fast so i tel them to come for a ride and they change there mind after that. i dont see how and why it does this. my ls integra felt more powerful (after 1st) then my tsx. someone help me out. im wondering if its just the stock ECU and maybe its so restritcting or something. when is hondata coming out and would that possibly help. im lost.
Old Sep 27, 2004 | 07:08 AM
Dan Martin's Avatar
Photography Nerd
Yes 2nd gear is a little too tall IMO. Hondata will probably be able to help out the transition from 1-2 by lowering the VTEC crossover to somewhere around 5000 rpm. Really there's not much that can be done unless you get different gears.
Old Sep 27, 2004 | 11:24 AM
b_jai's Avatar
hondata
Can you briefly explain what is hondata?
and usually what is the price of hondata?
Thanks!
Old Sep 27, 2004 | 11:53 AM
6 speed yo!
so there no way to fix this. shit im gun get a new tranny haha. it sucks cause i always pull away from people and then when i shift to 2nd they pull away.
Old Sep 27, 2004 | 12:12 PM
Dan Martin's Avatar
Photography Nerd
Thanks!
https://acurazine.com/forums/showthread.php?t=5131
Hondata is working on a reflash for the ECU and a replacement ECU called the K-Pro.
Old Sep 27, 2004 | 12:14 PM
fdl's Avatar
fdl
You've got to bury the tach in 1st and then let the clutch slip a little when switching to second.
Old Sep 27, 2004 | 11:07 PM
6 speed yo!
but i double clutch in 1st
Old Sep 27, 2004 | 11:08 PM
Dan Martin's Avatar
Photography Nerd
Old Sep 27, 2004 | 11:15 PM
Chompin's Avatar
Double Clutch?????????????? Are we still doing that????
6 speed yo!
shit it works jus not on this car. i swear my old integra was faster.
Old Sep 27, 2004 | 11:32 PM
JTso's Avatar
Ooh boy...
Old Sep 28, 2004 | 12:41 AM
6 speed yo!
i dun get it. nevamind your like 10-15 years older than me so its coo.
Old Sep 28, 2004 | 01:00 AM
biker's Avatar
Blame all those folks that wanted good 0-60 times. With a closer 2nd you wouldn't be able to get to 60 in 2nd.
Old Sep 28, 2004 | 06:55 AM
Dan Martin's Avatar
Photography Nerd
Don't double clutch. It sounds impressive to your friends but it doesn't give you any performance advantage. You won't be able to shift quick enough to keep the engine in the higher cam setting if you double clutch.
Just run 1st gear to 7300 and shift normally to second and you should still be above the VTEC engagement point.
Old Sep 28, 2004 | 09:58 AM
ClutchPerformer's Avatar
Double clutching on upshifts (with the intention of going fast) is Teh Fast and Teh Furious garbage. Save it for double-downshifting and such.
Old Sep 28, 2004 | 10:45 AM
Dan Martin's Avatar
Photography Nerd
Old Sep 28, 2004 | 12:36 PM
6 speed yo!
well obivously it doesnt work on this car. my last car was an ls and i could hang wit gsr's so it does work. just not on this car. i think the wrx does the same thing just not as bad.
Old Sep 28, 2004 | 12:43 PM
Lung Fu Mo Shi's Avatar
Registered AssHat
Same thing on your LS. Double clutching died with the invention of synchronizers.
Old Sep 28, 2004 | 12:47 PM
well obivously it doesnt work on this car. my last car was an ls and i could hang wit gsr's so it does work. just not on this car......
What do you mean it "doesn't work"?
How does one gauge if double clutching "works" or not?
Old Sep 28, 2004 | 12:49 PM
6 speed yo!
it doesnt pull. trust me ive tested it out. i ran my car without double clutching and then with and it does work.
but w/e please close the thread i already got my answer thanks
Old Sep 28, 2004 | 12:58 PM
dzuy's Avatar
Troutslap Mod-DUH-rator
get a comptech S/C when it comes out
btw,
:padlock:
divac
Aug 29, 2018 10:13 AM
Heyzuez20
Oct 14, 2015 07:18 AM
datadr
Sep 12, 2015 09:12 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
Hau_nguyen91
Sep 6, 2015 12:53 PM
