Spring Break
Spring Break
Hey yall im lookin to do a few mods on my tsx this spring break.. first off ima throw in a Injen CAI. im gettin it for $199, havent seen a better price then that yet. but im not sure what to expect for my other mod, Eibach pro-kit. The guys over at Racing Zone in orlando said that they can get me neuspeed for about $140.. thas pretty cheap. They also have the Eibach, but i forgot the pricing they gave me. I heard Eibach is a better drop for a tsx with 19's on it. um.. can someone help me out on the pricing.. what should i expect for the Eibach?
Also, Z, you need to help me out with some pricings man, i kno you cool with Racing Zone
Eibach and Neuspeed springs are both good products. I would also suggest that you invest in a rear camber kit because 19” rubber is not cheap. The camber kit will get the rear back into alignment to prevent abnormal tire wear. From what I can tell, the front drop on the Neuspeed Sport Springs and Pro Kit does not require a camber kit. The ride quality after lowering is very subjective. IMO a better set of dampers is required to get a near factory ride. But, I am trying to keep the wife happy with all the mods too, so ride quality may not be the biggest factor for your application.
BTW, the Injen and K&N Typhoon are both great CAI. You will be happy with either one.
so i need to get that plus the springs so totalof 340 plus installation and a injen for 199 plus installation... well gotta save atleast 650 dollars, u guys think the mods are worth 600+ dollars
Also, do not forget the alignment after you install the springs. That is required so do not skip it if you want your car to track straight and avoid tire wear.
nice deal for the neuspeed...i got jipped jk, glad you got a good deal
i would def go for the drop as it would make ur ride look a hella lot better (saw pix of ur ride and u def need it ). as for the intake i wanted the injen but i'm holding out to see if aem will come out with a intake/w bypass valve
so i guess yes getting ur ride lowered is worth the $$$...if you dont care about having a bypass valve on ur intake then i would get the injen as well
the bypass valve is in case the CAI takes in water. i've encountered some major puddles on my short commute to/from work so this will def be useful for me.
Air Bypass valve for Cold Air Intake Systems totally eliminate the unlikely chance of water ingestion should the filter element become wet from deep puddles, rain, hail. Sleet or snow, or any other submerged in water. The valve installs along the upper portion of the inlet pipe on the same axis as the throttle body centerline. Should a drop in pressure occur within the pipe, the valve shuts down induction at the filter and routes incoming air through the valve¡'s external orifices, elimination any chance of water ingestion.
and the short ram is not out yet
Originally posted by Dani
AEM only makes a short ram system (which doesnt require a bypass) for Acura TSX
"SRS Only Application
AEM spends extensive time developing each air induction system for maximum performance. Whenever possible, we design a Cold Air system that routes the filter outside of the engine compartment to take advantage of cooler ambient air temperatures, and offer a Short Ram system as an economical alternative to our Cold Air system.
However, tuning the inlet pipe is crucial to performance, and certain applications respond to runner lengths that will not allow us to create a true cold air system. In these cases, AEM manufactures a Short Ram system only, as this design creates the most useable power for a given application."
that's what AEM says about the air inductance system for Acura TSX, and ya, i actually gave them a call and it turned out to be true, so i guess SRS is the only way to go if we choose AEM
the largest gain from AEM SRS is 8.4 HP and 6.5 ft-ibs both at 6750 rpm...
could someone please tell me where i can find the dyno test results for Ingen/K&N?i wanna see all of them at the same time and do a comparison for the max gain and at what rpm
thx
thx
thx Bender Unit!
now plz correct me if i read the dyno chart wrong...
for K&N:
tested on 6SP TSX
largest HP gain is 9.7 HP at 4330 rpm
any info for the TQ gain!?
for Ingen:
tested on 5SP TSX
largest HP gain : 11.1 HP
largest TQ gain : 4.7 ft-lb
both at 5220 rpm
for AEM like i said before
tested on 6SP TSX
largest HP gain : 8.4 HP
largest TQ gain : 6.5 ft-lb
both at 6750 rpm
so...is it fair to say Ingen turns out to be the best choice from above? (largest HP gain and at OK rpm range), or there should be other more important factors i should be considering on?!
thanks guys!...
for K&N:
tested on 6SP TSX
for Ingen:
tested on 5SP TSX
both at 5220 rpm
tested on 6SP TSX
both at 6750 rpm
thanks guys!...
I wouldn't want to start mess'in up your thread but you might have to consider the location, ambient temp, and altitude of the place where these cars are dyno'd. Also, you have to see if the car has broken in yet.
To my eyes I feel like Injen provides the biggest gains since it got the highest number on an automatic tranny.
Thas why im gettin that INJEN by the end of this spring break.. 1 week to go.. also prolly gunna stick with the Eibach... and ima ask to pay 200 for it... so lets see how that goes
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
