Removed lower grill insert to help CAI...
Old May 29, 2006 | 11:29 PM
JohnnyMilano's Avatar
Pimpin' aint easy
Decided to take off the lower driver side small grill insert where the foglights would go to get some extra air to the CAI. Nice quick mod to play with on a dry day. I guess you can say its kinda like a hood scoop.
Old May 30, 2006 | 05:43 AM
Built B16A's Avatar
Old May 30, 2006 | 07:27 AM
LoveMyTL-S's Avatar
You just removed it? Did you replace it with something else, like a screen?
HoRRo's Avatar
iVTEC no koe
Prolly works really well, but I can't stand the look. Shaving off the back of the insert is what I did.
Old May 30, 2006 | 08:30 AM
Newplay1's Avatar
08 MDX with Sports
That looks pretty good shaved, I might get mines painted..
Old May 30, 2006 | 08:47 AM
jiggaman's Avatar
I spend 2 much time here
shaved is always my preference...
Old May 30, 2006 | 08:55 AM
LoveMyTL-S's Avatar
Old May 30, 2006 | 08:56 AM
LoveMyTL-S's Avatar
The cut-out fog light cover looks good. I may do that.
Old May 30, 2006 | 09:27 AM
curls's Avatar
Someone stole "My Garage"
What tool(s) required? Dremel w/ cut-off wheel? Or hacksaw? What did you use?
Old May 30, 2006 | 09:44 AM
JTso's Avatar
I did it when I installed the K&N CAI.
Old May 30, 2006 | 10:02 AM
jiggaman's Avatar
so u guys swap out that cover with a "unshaved" one everytime it rains?
Old May 30, 2006 | 03:36 PM
daddydliv's Avatar
Faster, please.
I considered doing this before but the thought of having the opening makes me weary. Cleaning/re-oiling the filter is a PITA to me and I assume that cleaning is necessary more often with this done. Any feedback JTso?
Old May 30, 2006 | 03:47 PM
JTso's Avatar
I have the K&N drycharger on the filter and no cleaning required yet. It's easy enough to remove the filter through the wheel liner if necessary. It should not take more than 5 minutes.
Old May 30, 2006 | 04:00 PM
xizor's Avatar
Bye TSX, hello domestic?
rain wont affect your CAI filter, so no, you don't need to swap it
Old May 30, 2006 | 04:13 PM
jiggaman's Avatar
are you being sarcastic? i thought that getting water on it was a big no no. is it only if water is actually sucked up the intake tube and into the engine that you run into trouble? how much water is needed to cause a mechanical malfunction? and while i am at it how are babies made?
Old May 30, 2006 | 04:27 PM
Dan Martin's Avatar
Photography Nerd
You have to fully submerge the filter to ingest enough water to hydrolock your engine.
Old May 30, 2006 | 05:12 PM
SimpleWhite's Avatar
Various companies sell water shield...Injen for example.
Old May 30, 2006 | 07:14 PM
drunkenbuda's Avatar
Got Phó?
I had my Injen for a year, i live in WA where it rains a lot....no problems so far...knock on wood.....
Old May 31, 2006 | 08:28 AM
HoRRo's Avatar
iVTEC no koe
I didn't use any dremel tool, just one of those big xacto knives and sliced it. I only needed to shave off about 2-3mm.
Old May 31, 2006 | 09:40 AM
jiggaman's Avatar
i like the way yours came out horro, impressive for only using an xacto knive
Old Jun 1, 2006 | 08:14 AM
daddydliv's Avatar
Faster, please.
Doesn't the drycharger negate the effect of having the opening? I may still do this and just suck it up more often to do the cleaning. It's not the actual removal/cleaning that's a pain it's the time waiting for the filter to dry that becomes a nuisance. I guess I could just buy a second filter and rotate them for time's sake.
Old Jun 1, 2006 | 10:53 AM
curik_euro's Avatar
Yohan
what happens if there is a foglight in the slot???? NOOO, II'm losing a few ponys!!!
Old Jun 1, 2006 | 11:24 AM
daddydliv's Avatar
Faster, please.
What????
Old Jun 1, 2006 | 12:26 PM
jiggaman's Avatar
remove the fog light
Old Jun 1, 2006 | 07:12 PM
curik_euro's Avatar
Yohan
Remove them? I need them when the weather isn't friendly. Does the CAI still perform as good without the vents?
Old Jun 2, 2006 | 09:38 AM
brian3b's Avatar
I installed my Injen CAI a few days ago and tried it out... sounds nice, not sure if the gains are too noticable. I cut the slots out on the insert last night, so I'll try it out again to see if there's a difference...
Old Jun 2, 2006 | 10:05 PM
Chris_F's Avatar
my car with inserts removed. those fog light covers are ugly - been thinking of getting the plastic foglight surrounds minus the foglights to put in their place
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Sep 17, 2015 09:01 PM
Skirmich
Sep 15, 2015 06:41 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
