RedShift Motorsports Supercharger
#161
If i can get the money together, which i'm hoping too, i would def be down for the stage 2 as long as the AT can handle the power without a lot of other mod's!!!
Chris- do you guys have hours on saturdays?? I would like to stop by one of these days but only have off on weekend normally!
#163
Polar Chicken
Yea right
Originally Posted by RaCeR4LiFe022
370 if intercooled... ahhhh i want!
im going to call them tommarow and see if they can give me any info on the kit
#165
Boost Junky
Originally Posted by Zasker1
Kenny,
How is the wheel slip with the Comptech SC? Is an LSD a must?
#168
Received 3,763 Likes
Originally Posted by rmpage
If a manual can handle it then an auto definitely can.
#169
Just dial 1911
1 Post
Originally Posted by TSX559
Ill go with a stage 2. Only if it pass CARB. Im in cali with a 04 5AT. Otherwise, Ill just go with a Comptech SC instead.
And count me as two as this is a consideration for me once the warranty is up.
#171
Boost Junky
I am not following the thought process.
#173
#174
Originally Posted by simplyscion
+1...please dont tell me Honda builds stronger auto trannies than the manuals...that would just be so sad ![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
#175
Originally Posted by moda_way
I'd be concerned about the clutch packs, valves and seal to start with... That doesn't even begin to talk about the torque convertor, cool (though the stock may be adequate). I'm not saying the AT will blow up on first launch, but at 310hp, that's 1.5 times more power being sent through the tranny. I'm pretty sure Honda doesn't test their OEM equipment for that much stress. Question is, who will be the first to find out?
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
#176
Drives With Hands
#178
Rep'n Taxbrain.com
I am not aware of any car that gained 90hp via in intercooler. This kit must have a different pulley as well.
Kenny,
#179
Generally speaking, a hydrostatic coupling's viscous nature (e.g. its ability to slip under high torque) makes it much more tolerant of high loading than a dry clutch is. Instead of pads scraping against a plate you have two impellers immersed in a fluid, between which there is no direct mechanical connection. As long as you can manage heat properly by cooling the ATF fast enough (easy), the operating envelope of an AT will extend beyond that of an MT rated for the same capacity by a sizeable margin.
I have no idea what the AT is rated for, but I don't see why they'd design the manual to handle more power when it's in the same car. Any time you push a system beyond its design envelope, stuff breaks faster.
#180
Drives With Hands
True, loading an AT is far easier to manage than a dry clutch.
#181
That's what I've been saying. The guy questioned whether or not the stock AT could hold the power of a Stage 2 kit. Unless the people with MTs are melting clutches, he has nothing to worry about. The TSX 5AT, or any AT, is stronger than its manual counterpart by virtue of its design. I wasn't discussing modified transmissions. If you're willing to go down that road, almost anything is possible provided you can pay for it.
#182
I will let you know how long my stock clutch lasts....I am using my own civic si and my own tsx to test these kits so...I may be installing a new clutch but I doubt it. I will let you guys know
#183
Originally Posted by Redshiftmotorsports
I will let you know how long my stock clutch lasts....I am using my own civic si and my own tsx to test these kits so...I may be installing a new clutch but I doubt it. I will let you guys know ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
#185
Not as of yet, but as the rest of our parts it is going to be TOP quality, just like our customer service is
Like you know how people with other kits on different cars can have issues with tensioners and belt slippage I want NO issues with our kit. No shredding belts, slipping, etc!!! That is something that is something that I feel is lacking in the aftermarket industry with alot of companies customer service!! That is were we will excel. That is also why we are not trying to skimp on ANY of the parts we use. I would rather have it over engineered that under!!
I am not going anywhere I am working on modding my Navi couldn't do it without this site
#186
Drives With Hands
Yeah, I'm glad you guys seem to be making your presence firmly known here. That's a great confidence builder for me. Hondata does the same thing with who knows how many forums and it's awesome to have Doug come in here every now and then and set us right on a question. We all appreciate it.
#190
I spend 2 much time here
Were still here, development takes time
We want it perfect not just right.
#191
Rep'n Taxbrain.com
Any news from Hondata about the engine management and whether they've been able to tune and control the fuel under boost conditions on the TSX?
#192
^^yes, any update on engine management? anything you can divulge to us yet?
can you confirm/deny any hesitation between 2-3k rpm? (those with ct s/c will know what i mean)
#193
Not as of yet, BUT I can garen-dam-tee you we will make this work. I own a TSX myself so I want this kit just as much as any of you
Oh I check evey night
Where not going anywhere!!!
No idea about the hesitation, what do you guys think it could be? I haven't played with the comptech kit B4. I could guess :0
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
#194
Rep'n Taxbrain.com
The main theory that I've heard is the that the ECU is staying in closed loop mode for too long and the hesitation comes as the ECU is switching from closed loop to open loop mode. In talking to Comptech and Hondata, apparently the TSX ECU and a lot of the newer ECUs are staying in closed loop mode a lot longer than they use to. So as this transition is happenning then there is a slight hesitation and then a surge of power once the ECU goes into open loop mode.
I've tested this theory by running for a month with my primary O2 sensor disconnected. Disconnecting the primary O2 sensor will force the ECU to stay in open loop at all times. Doing this actually helped a whole lot, the hesitation was just about gone, but the problem was it made my idle kind of irractic at times since the ECU did not have an air/fuel ratio reading to help it maintain a perfect 14.7. It also made me run richer, since the the A/F ratio for a supercharged TSX is tuned to be lower for engine safety reasons.
I've heard that Hondata came up with a new method of engaging open loop mode that was suppose to almost resolve this problem. I'm still waiting for a new TSX SC reflash with this fix though.
#195
That would make sense cause the Comptech probably doesn't really start to boost until then correct? I think maybee making the transition smoother will solve this if this is truly the issue. We will def. address any issues on our kits B4 they are released.
#196
Rep'n Taxbrain.com
What's interesting though is that the transition is much smoother if I let the RPMs go to about 4K and then mash the gas. If I mash the gas before 3K, that seems to be the situation where I will experience the slight hesitation more often.
Have you guys decided where you will put the Vtec engagement point? Or will you be doing a Vtec window?
#198
my car is ready and sitting in my garage waiting for the notification to delieve it so you can work on it.
#199
my 06 pwp waiting outside the parking lot....to bolt that Rotrex and show the world wut Vtec can do when supercharged....
and quite honestly to make my G35 friends cry in front of me ^ ^
#200
Originally Posted by Tsx536
Yeah the boost doesn't really start until you hit Vtec. When Vtec enages it will put the ECU in open loop mode. Hondata tuned a Vtec window between 3K and 5K RPMs so Vtec will engage based on throttle position and the MAP reading. I'm not 100% on whether the MAP reading effects the Vtec engagement point, but it appears that way when I check my readings.
One thought I have is that this hesitation could be somewhat related to the bypass valve on the supercharger.... I don't know obviously, but my experience is that low rpm transition to boost in a Eaton S/C setup often results in slight delays and sporadic boost transition. But going open loop, you may be either helping the confusion in the ecu (because there isn't as much to decide) or you may just be deadening the power delivery and how it feels because of an over-rich condition. Of course, Doug at Hondata I'm sure understand this better than I do, and it may be completely different than that.
I'm sure we'll learn what it is evenually because we may run into it eventually.
Chris at RedShift
