Question about header
Originally Posted by clee109
just be sure to get new gaskets! Stock gasket for where the engine meets the header and stock gasket for where the header meets the cat
Good point, you don't want any leakage...
Originally Posted by Reach
I've done at least 5 header installs now with nothing but floor jack, jack stands, and hand tools. Its a very easy job on the TSX, as long as you can break the rusted up stock hardware loose!
Is there anything i should definately know about the install? are there any parts of it that are like the hardest, or a big pita? pretty straightfoward? ive looked at all the diagrams, threads, pics, etc and it does look pretty easy.
bottom left bolt on the stock header is a major PITA, it's at a tough angle, I resorted to an impact wrench to get it off. At the time my 06 had 17,000 miles on it. Just be sure when you are breaking the bolts loose to keep the socket firmly planted on the bolt, no angles because if you break it loose at an angle and not full on the bolt you'll end up stripping the head of the bolt.
Im looking at this diagram, and part list and there are two listings for exhaust manifold gasket, both have diff part numbers.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
i need both?
according to that diagram you posted you will need gasket number 3
You will also need the gasket that is between the header and cat which is just a ring
2 Different part numbers, Two different prices.
Originally Posted by 925tsx
Number three is listed twice.
DerrickW
11-15-2015 05:52 PM
