Nuespeed strut-bar
Nuespeed strut-bar
Nuespeed bar yes that thing is pita to install!
I tried driving to flat surface because someone said it should go right in but the darn thing will not line up straight into the 4 holes.
Same as the comptech, loosely attached one side, then you should drop the other side's shock/spring assemblies and then push it back up. Goes right on. Since I recommend the car being jacked up, you use the jack under the side you drop so that the shock/spring doesn't slam down.
CL9 ABP
Both wheels need to be off the ground for it to fit, I thought I jacked the car high enough but I had to use the stock jack to the max height with jack stands after...
Originally Posted by Newplay1
Can I use those heavy duty jacks to lift from primary jacking point in the front of the car instead of using 2 jacks on each sides?
here's how I did it, I put the driver side on first and lightly tightened it. Then I used a pry bar to align the passenger side and pushed down pretty hard, then lightly tightened those bolts. The bar will rub the a/c line a bit, but seems to only be pushing on the insulation.
Once I had the bolts lightly tightened I torqued the passenger side first then the driver. Then drove for a while and retorqued.
xaznperswaesonx
Mar 11, 2009 01:10 AM
xaznperswaesonx
Oct 11, 2008 06:52 PM
