My first mod - Icebox install
Hey all, finally did a real mod. Thanks to everyone's posts here, the installation was a snap. Had the right tools and only took an hour. One question: The instructions show the snorkle fitting further into the bottom of the airbox but I could not get it to fit any tighter than it is. Did I do something wrong? It looks like everything is in the right place.
I love the sound, just what I was looking for.
Does it come with an Air Bypass Valve? And if not, arent you worried about water getting in your engine? I would be. Which is why I dont want to get a cold air intake. However, I do want the Icebox. LoL, so confused.....
Couple things:
-- The bottom of the stock airbox which is resued is vented. Meaning even if you submerge the snorkel air will be sucked in via the bottom of the stock box. you'd have to submerge your car up to the bottom of the airbox to make hydrolock likely.
-- The iceobx will be pulling in air just as cold as the injen as it's drawing from the same location, so in that regards it is a "cold air intake". The differentiation is that it is not an "open element" intake.
IMHO, the icebox is a more conservative way to go as opposed to the injen/K&N cai or sri, which probably provide greater gains but also come with a greater change to the car's sound. In my situation, I wanted to keep her quiet and the icebox was a nice compromise. Slightly better throttle response, only $150 and keeping the car relatively quiet throughout the rpm range. (maybe a slightly deeper growl on wot than stock)
and of course,
icebox plus hondata = very, very nice gains while closely retaining stock look/sound.
and of course,
and of course,
and of course,
Exactly why I went with the Icebox. Sound is not obnoxious, my butt dyno can feel HP increase at WOT and there is a nice grow. Looking to get Hondatified sometime soon so the icebox (or any CAI) is almost a must.
Originally Posted by Type X
did you remove your bumper for the install?
or did you go thru the fenderwall?
any sound clips of the unit?
I went through the fenderwell with the wheel removed. It was a piece of cake. Even the hard to reach bolt wasn't that difficult to remove with the right tool.
Originally Posted by pcaulfie
No sound clips. Sounds just like the clips you can find on this forum.
i didnt have it
Also, I'm not trying to be a smartass but my impression of the Icebox is that it's basically a little bigger, smoother airbox and a plastic snorkel that replaces the resonator. Does anyone else think that's not much for $150? I don't want an Injen/K&N/AEM CAI because I don't want loudness, but replacing the resonator with a plastic tube seems like something I can get at a hardware store and just grind down the lattice in the existing airbox with a rasp and some sandpaper. Thoughts?
No bypass valve, but the general consensus is you'd have to fully submerge your front end to worry about hydrolocking your engine. I think I'll use my Tahoe to drive through streams instead.
So, I wouldn't worry about it. Your mod looks good.
Originally Posted by jlukja
My Icebox installation experience: Post # 46
I read your thread regarding the swaybar, that's a mod I want to do so I just bot it from Acura of Escondido (eBay). That and a reflash (as soon as I figure out how to be without the car for a few days) and I think I'll be done -- it's my daily driver and will be for many years so I don't want to mess with it too much!
TLDude876
Dec 28, 2016 03:18 PM
BoricuaTL
Apr 8, 2016 01:08 PM
Nitin
Sep 30, 2015 08:22 PM
