Lightweight Flywheel
Old Feb 7, 2005 | 08:35 PM
fedlawman's Avatar
I gave the service shop the go-ahead to install the Comptech lightweight flywheel
https://acurazine.com/forums/showthread.php?t=19840
$330 for the part, $0 for the labor. How could I say no?
I should have my TSX back by the end of the week. Can't wait!
Old Feb 7, 2005 | 08:50 PM
JTso's Avatar
Cool! don't forget to weight the stock flywheel for comparision.
Old Feb 7, 2005 | 09:04 PM
fedlawman's Avatar
Right! I'll make sure they keep the original for me.
Old Feb 9, 2005 | 08:27 AM
fedlawman's Avatar
Comptech doesn't have it in stock. It'll take 2 weeks for Acura of Seattle to get it in.
I either take a pass on the part, or pick up my TSX and bring it back again when they get the flywheel.
Bummer!
Old Feb 9, 2005 | 09:11 AM
CCColtsicehockey's Avatar
pick it up and go back and get it later
Old Feb 9, 2005 | 09:19 AM
crxmanror's Avatar
Yeah the Comptech Flywheel is a pretty nice piece. I had Acura install it for me when they had to rebuilt my 6MT. The flywheel weighs approx. half the weight of the stock flywheel and man let me tell you does the car ever rap out quick.... Car needs higher rev limter.
Old Feb 9, 2005 | 12:26 PM
AZTSX's Avatar
I agree youre getting a great deal!
Old Feb 9, 2005 | 02:53 PM
fedlawman's Avatar
OK.
I was starting to have second thoughts, but you've convinced me.
Old Feb 9, 2005 | 02:55 PM
AZTSX's Avatar
almost all the time the labor is what the majority of the payment goes to
Old Feb 9, 2005 | 04:37 PM
TSX Cman's Avatar
im kinda excited about this. if it revvs out too fast, does that mean its picking up speed that much quicker?
as in is the rev:speed ratio equal on both flywheels
Old Feb 9, 2005 | 04:38 PM
kurt_bradley's Avatar
If you have to go back again later, you're going to have to pay for the labor. They're doing it for free because they'll have the case out with the flywheel exposed. if they have to start from scratch again, it usually takes a good 5 hours to swap.
I know this because I used to work for an Acura service department until last year. my faster (or more experienced) techs took about 4 hours to do a TSX tranny (it's more diffictult than, say, a 2002 TL because it has a different cradle that requires different support). The customer pay labor rate was $90/hour, so expect to have to drop a bunch of cash to get this installed if you have to take it back in.
Old Feb 9, 2005 | 07:03 PM
madmanmax3000's Avatar
Professional Newbie
alright guys, i'm gonna admit that i'm lost here...i know what a flywheel is, but what exactly are the benefits here?
Old Feb 9, 2005 | 07:09 PM
The lighter the flywheel, the faster the revs. This is good to a certain extent. The lighter your rotating mass, the lower the restriction on the engine, and the more free-flowing ponies. If only we could re-map our ECUs to better accomodate faster revs with a higher redline and smoother fuel mapping.
Old Feb 9, 2005 | 07:31 PM
Professional Newbie
so does this mean that the flywheel would show noticeable HP difference, roughly how much?
Old Feb 9, 2005 | 08:40 PM
JeffTSX's Avatar
Subie Tech
There is no HP difference. Hmm..okay, Just imagaine this. It's kinda like how your car would feel if it lost some weigh.
Old Feb 9, 2005 | 08:54 PM
TSX Cman's Avatar
wow, you guys need to explain this ALOT better.
liek asnwering my question, is the speed of your car at 7000rpms the same as changing to a light weight flywheel? a ratio of speed: rev equally throughout the band, cuz if thats the case... if it took 6 seoncds to rev up to redline before, and it now takes 4 seconds, but the speed is speed to rev ratio remains equal.... than your car goes significantly faster?
i just dont get how it works. you rev faster, thats all. and jeff's odd comment.
Old Feb 9, 2005 | 09:12 PM
JTso's Avatar
Try this...
Old Feb 9, 2005 | 10:18 PM
fedlawman's Avatar
[QUOTE=kurt_bradley]If you have to go back again later, you're going to have to pay for the labor.QUOTE]
My service advisor told me that they didn't open up the transmission to diagnose the problem. I can pick up the car, drive it for a couple of weeks, and then bring it back to do the warranty work AND install the flywheel at the same time.
Old Feb 9, 2005 | 10:44 PM
fedlawman's Avatar
Since the flywheel is attached to the engine at the crank, it reduces the amount of "work" that the engine must expend to turn the crank, thereby passing more of the "work" to the road. The effect is most pronounced in 1st gear, still significant in 2nd gear, and becomes increasingly less potent in higher gears.
Here is an excellent explanation that JTso provided me.
http://www.pumaracing.co.uk/flywheel.htm
Basically, it says that in 1st gear, removing 10 lbs. from the flywheel will be the equivalent of removing approximately 400 lbs. of weight from the car. In 2nd gear, it would be equal to about 120 lbs. of curb weight. 3rd gear is like 60 lbs., etc.
Here is an old link that illustrates the effect of reducing the weight of a car.
http://sportcompactcarweb.com/features/0208_scared/
In this article, a Nissan Sentra shaved 1/2 second of it's 0-60 MPH time simply by shaving 13 lbs. off of each wheel.
Combine a lightweight flywheel with lightweight wheels/tires and you could easily knock 1 second off the TSX's 0-60 MPH times...and that's without touching the engine!
Old Feb 9, 2005 | 10:48 PM
sauceman's Avatar
Moderator Alumnus
Originally Posted by JTso
A very good read!
Old Feb 9, 2005 | 10:53 PM
[QUOTE=fedlawman]
So they haven't done your tranny yet? Odd that they didn't want to get that job booked as quickly as possible.
Old Feb 10, 2005 | 09:24 AM
fedlawman's Avatar
Yeah, I was surprised too. I assumed that they had already opened up the tranny and were waiting for the new throw out bearing to arrive.
Old Feb 10, 2005 | 09:54 AM
Zapata's Avatar
Cost Drivers!!!!
whoaaa, wait..........reciprocating mass is different than static mass. There will be slight differences for sure. If you were to add heavier rotors or heavier rims, you will dyno less power for sure....the opposite is true. It's not a power adder per say just reduces parasitic loss.
Old Feb 10, 2005 | 10:00 AM
TSXDude's Avatar
Noobie 6MT driver
Will it affect driveability when you install a lightened flywheel? I would think that the drop in rpm would be much quicker when you have a lighter flywheel.
Old Feb 10, 2005 | 10:05 AM
Zapata's Avatar
Cost Drivers!!!!
yes, RPMs do drop quicker. Starting from a roll is also a bit more difficult because of how easily the engine will spool. Just a matter of adjusting. Everybody i know, no matter on what car(aside from FI) said it's the best upgrade they could've done. Lightened rotors and rims are the next thing because of the peformance gains in acceleratoin and deceleration.
Old Feb 10, 2005 | 04:07 PM
TSX Cman's Avatar
haha damn. i want my car to move a little quicker, but i want some 19 inch chromers from RJ.
Old Feb 11, 2005 | 04:35 AM
sauceman's Avatar
Moderator Alumnus
I'm one of those too.
Old Feb 11, 2005 | 11:41 AM
cmf's Avatar
cmf
ATCer
So what are the cons of this modification? I see plenty of positive things.
Additionally, does anyone know of any other companies selling lighter flywheels. Aside from maybe a supercharger, I am not really looking to drop Comptech parts in my car, regardless of warranty situations provided by a dealer.
Old Feb 11, 2005 | 12:27 PM
I'm not entirely sure, but I wonder if the Exedy clutch/fly combos for the K20 will work with the K24. The structural differences in the engine for displacement are in the bore x stroke.
Exedy homepage
The HF02 flywheel mates to all 3 transmissions for the other K20s (Si, RSX, and Type-S)
Old Feb 11, 2005 | 02:56 PM
vwong's Avatar
n00b
I was thinking the same thing. But when I looked at the pictures of the Comptech flywheels for the RSX and the TSX, they look different (assuming the pictures represent the actual parts). Take a look at the pics below.
Comptech RSX lightweight flywheel
Comptech TSX lightweight flywheel
Notice that there are 3 more mounting holes (for the clutch housing) on the RSX flywheel. Also, the center bore appears to be a little bigger on the TSX flywheel (the stock crankshaft maybe bigger?). Since Comptech makes the flywheels for both cars, maybe someone can call them and find out.
Old Feb 11, 2005 | 03:11 PM
vwong's Avatar
n00b
I don't think there is any cons for this mod.
May I ask why you don't want Comptech? Just curious!!!
I think at this point of time, only Comptech makes a lightweight flywheel for the K24 motor (TSX). I hope to see other companies to come up with one also. Companies like Exedy, Toda, Spoon, or JUN. Just some things for those who are interested in getting a lightweight flywheel, IMO I would only go with a flywheel that is made out of chromoly steel (basically all the companies I listed above, including the Comptech one). I would avoid one that is made out of aluminum alloy (like the Fidanza one). The reason is that (based on my limited knowledge on metals) aluminum is usually softer and cannot withstand high heat, therefore a flywheel in this material tends to warp easier as compared to the chromoly steel. Now, I've heard people with Fidanza flywheels and they're happy with them. It's just my preference that I would avoid aluminum flywheels.
Old Feb 11, 2005 | 03:30 PM
BlackTSX's Avatar
Jewdacris!!
Car mechanical wise im kind of a n00b, so im wondering....is this something that could be done to an auto, or is this a manual only type mod? If so, would it serve any benefit to an auto?
Old Feb 11, 2005 | 03:55 PM
vwong's Avatar
n00b
This is a MT only thing.
Old Feb 11, 2005 | 04:06 PM
BlackTSX's Avatar
Jewdacris!!
I kind of thought that but i wasnt 100% sure...
thanks for clearing that up vwong
Old Feb 11, 2005 | 04:31 PM
TSX Cman's Avatar
the only thing thats disappointing me is that this is a gain for 1st gear mainly. i already needlessly burn more gas than needed. i am trying to cut down the 1st gear accel and put a little more into 2, 3.
Old Feb 11, 2005 | 07:12 PM
JTso's Avatar
The only con that I can think of, for an extremely lightened flywheel is the possibility of the engine stalling during quick stop at the light, due to the reduction of momentum.
Old Feb 11, 2005 | 11:43 PM
cmf's Avatar
cmf
ATCer
Just not a big fan of Comptech is all. I'm not saying it's a bad product, but just don't like their stuff.
I'd rather go with one of the Japanese companies, gotta keep it JDM yo!
Old Feb 12, 2005 | 12:47 AM
xizor's Avatar
Bye TSX, hello domestic?
a con could be the fact you'll engine break less... if someone could consider that a bad thing. and as jtso alluded, does it make the idle somewhat rougher?
Old Feb 12, 2005 | 10:25 AM
Stokeless_TSX's Avatar
Stokeless
In past experiences with lightweight flywheels on my other Hondas I have never noticed engine being rougher just acceleration increase and faster reving. And I'm with CMF I just don't like comptech. I think they are over priced and don't perform as well as other brands that are in the same price range or even better priced. BUT that is MY opinion I'm not preaching or tryin to talk crap I just don't like thier products too much. For example..the I/H/E combo costs how much???? My custom set up was only $600. With just I/E and I make more power than the I/H/E combo from comptech. Thats sad IMHO.
Old Feb 12, 2005 | 05:09 PM
cmf's Avatar
cmf
ATCer
Curious to know why you'd engine brake less. I do that a lot, so increase my knowledge please.
