k24a2 v. k24a4
k24a2(tsx) is the same design as k20a2(rsx type s) , so its a three lobe system.
Plus the piston compression is different as well.. tsx are 10.5 to 1 while the other k24a1 , k24a3 are less than 10.
Cost Drivers!!!!
ah ok but what abotu the k24a4....is that a 3 lobe? I thought it was two.
Stokeless
ummm from what i have read and been told the k24a2 has a completely different head set up than the k20a....rsx -s engine. and i believe this is correct since we cant use the dc5 type R cams....and the RSX can. Imod i believe tried them and they didnt fit...
k24a2 is the only engine that has a 3 lobe system!!!
even the k20a2 head is diferrent than the jdm k20a.. k20a uses double valve spring.. thats the only difference..
On the Sport compact car magazines.. THey used the CRV block with the TYPE S head with type r cames i believed. And using HONDATA K-PRO to run it..
K24A2 (TSX) - 3 cam lobes on intake and exhaust cams, and EGR porting (Performance VTEC)
K24A4 (Accord & Element) - 2 cam lobes on intake, 1 cam lobe on exhaust cams, EGR porting (Fuel Economy VTEC)
K24A1 (CR-V) - 2 cam lobes on intake, 1 cam lobe on exhaust cams (Fuel Economy VTEC)
Cost Drivers!!!!
ah thanks!!! exactly what i was looking for.....
gixer08
19
04-27-2012 03:43 PM
slats
14
09-29-2005 10:15 AM
