I installed my icebox this weekend...
...i probably installed the icebox the hardest way possible ;(
i didnt feel like taking off the bumper so i removed the wheel and liner and got 1/2 the resonator out when i realized there is no F***ing way i was getting the bitch bolt out. My arm must be too big. I could get to the bolt but had no room to break it free/move it
So i got out the Dremel and just start to cut at the resonator. I cut the front, and the top off, then finally got enough of the hinge the bitch bolt was attached to inorder to use a crow bar to snap it it took about 30+ min to dremel it out.
After i got that out the rest of the install went smooth.
Once it was all done and i cleaned up the shavings i took the car on a 30min drive. The sound isn't noticeable under 4k, after that it has a slight growl, i wish it was alittle louder its all good...
I feel like the car has more pep, alot less lagged...which is a very nice change. It may have gained a little low end (under 3k), but mainly after 4k.
It was almost impossible to install w/o removing bumper for me. So I removed front bumper finally and after that, it became really easy BTW, If you want to go little bit louder, then I recommand you K&N filter. Mine got little bit louder when I changed the filter to K&N
i've been readin on the board for a long time.
from my understanding .. KN Filter > filter that came with ice box. ice box uses a foam type filter (unless they changed it recently). but i hear that from long usage .. the foam can deteriorate and flake off which will then be sucked into the motor itself. While the KN filter wouldnt deteriorate that fast due to cleaning and oiling of the filter.
i could be wrong .. if johnny reads this he can clarify,
Spoon uses a foam filter...you oil/clean the foam filter as well...
...if this is true how long till it begins to deteriorate?
Originally Posted by aaronng
You can only take the front bolt off without removing the bumper if you have an 04-05 and no foggies. Otherwise you have to either remove the bumper or peel down the splashguard under the bumper.
Yup. 04 with no fogs here, I just reached in and did it that way. It took me maybe 20 minutes to get that bolt out. Nowhere near as bad as reported, due to my setup.
wow. haha
i have an 06 and i got the bolt out easy. i looked in and im like wheres that effing bolt? when i saw where it was i took out one or 2 bolts under my bumper got my hand in, and in 10seconds it was out.
i dont have icebox yet tho. i was just taking my resonator out for now.
Yeah I don't know how you would get to that top bolt to take off the intake piece connected near the top of the radiator unless you take the bumper off. It was a bitch for me even with the bumper off.
I can't believe that those 8 or so cheap plastic push pins are the only thing holding up the bumper, no solid bolt or screw besides the two side screws. My Si had two solid bolts holding up the bumper in addition to the side screws.
i got everything out easy. i mean... i had to tug a little bit but it wasnt too bad and i didnt scratch anything or mess anything up
i seriously dont even know how that all came out. even the other tube that goes from the resonator back up to the radiator
i just remember i was feeling to lazy to remove the tire. i lifted the car and i was like eh and just turned the wheel and pulled the splash guard
yup, it's actually pretty easy to remove all that stuff. I cheated though as far as an intake. i bought a k&n drop in filter and connected a flexble tube from the bottom of the air box and ran it to the opening where your fog lights would be. I cut open the plastic fog light hole plug thing and zip tied the hose directly behind this so it's like a "Ram air" type deal since the hose is sealed at the air box.
Not to worried about screening or anything since the filter is still there but i'll prob screen it in here shortly.
Car is quite but once you get moving it feels a bit torquier. a little more responsive as well. Not sur but the butt dyno can tell a little diff but nothing big I don't think.
Originally Posted by Si_2_TSX
I am assuming you are using the stock Air Box Cover and not Comptech's bc the K&N filter doesn't fit the Comptech cover which sucks, just stock. I found this out when I switched out filters for the K&N, it did sound a lot louder but that was because there wasn't a tight seal at the air box.
Look here: https://acurazine.com/forums/showthread.php?t=25198
Just add some rubber strips to the comptech lid so that it presses down and seals against the K&N filter.
I just ordered a Injen CAI to try that out but I have been happy with the Ice Box, I just feel like I can get more from a std CAI. Maybe I am just biased since I have had a number of AEM's and Injen CAI's.
^^ the Icebox retains the lower half of the stock airbox which has airholes so it is more difficult to hydrolock.
Don't drive through deep puddles, or run your CAI in short ram mode during the rainy season.
Originally Posted by TommySalami
Hm, didn't think you could hydrolock in short ram mode
so most of you think the icebox is something worth investing ?? sorry this is probably off the topic but i just had to ask, because i have been thinking of getting it for a while since i got my tsx back in june
Former Sponsor
Originally Posted by TWONZ
^ What system is better???? More Power? $$$$$$$
IceBox
AEM
Injen
K&N
Fujita
IceBox
AEM
Injen
K&N
Fujita
Josh, were you thinking of this thread?
https://acurazine.com/forums/showthread.php?t=25092
cycdaniel
12-17-2019 10:58 AM
Nitin
09-30-2015 08:22 PM
