Foglight Rewire
#121
ok... been looking around for this but cant seem to find it so I'm going to post here again. I'm looking for the size for the screws that go under the foglight. The screws you use to adjust the aim of the fogs. I already know they're step screws, just need a size from someone. Preferably from someone who bought their fogs from ebay. Thanx
#122
CL9 ABP
OKay I just used the mrheeltoe wire hanress on oem fogs no problems really but a few small fitment issues that just had to be figured out yourself.
Foglights only come on when you have your hid lights so you need a separate controller to have more freedom .
#123
So the Mrheeltoe worked out then? you said the fogs only come on with your headlights? And then you said you need a seperated controller for more freedom? Are you talking about the common problem with having the fog lights on the stalk instead of having the button so you can turn them on and off as you please?
What kind of "fitment issues" are we talking about too?
#124
Originally Posted by dwest1023
As you can see, in the 06 tsx the ground connection that turns our fogs on is controlled by the relay control module. located under the hood. If you attach a wire to the white wire, coming from our stalk switch, to the blue black, under the fog light relay, you effectively bypass the module. Thus you can now turn on the fogs when ever you want. Hope this is clear.
Ok so i think i might have this figured out now. Under the fusebox is what looks like the fog light relay. If you just bypass this relay the fog lights might work anytime. I will try this when i have some light outside. if anyone else wants to try it let me know if it works. I figure connecting the white to the blu/black is just bypassing the fuse and will not do anything. but if you bypass the first or last relay might bypass the headlight input.
#125
CL9 ABP
it took forever to open the fuse box and those clip retainers.
#126
#127
Originally Posted by hanggaw
Anybody try this method yet? Pics greatly appreciated. Thanks.
This has already been done.
https://acurazine.com/forums/showthr...694#post654694
you just can't bypass the relay. If you look under the hood, you will see the fog relay. you need to find the blue black wire in the harness that goes to the relay. cConnect a wire to blue/black and to ground and the fogs will come on. Now, its up to you how you want to make the fogs come on. Once you connect this ground the fogs will be on all the time, so you need to use a switch or relay. I used both, and used a fog switch from the honda accord. fit the dash perfect.
The fog relay is hot all the time, wheather the ignition is on or not. The fog relay only needs to be grounded. My fogs are wired so they only come on if the parking lights are on. That way if I leave the fog on, when I cut the car off the fogs will turn off by themselves. That factory swith will still work the same. Once I turn my parking lights on, I can use my honda switch to turn the fogs off and on. Once I turn the headlights on, I can use with the OEM switch or the other.
#128
2006 ASM tsx
isn't there any way to complete this mod and still just use your regular switch the on that located on the same switch as your headlights?? the other thing u just turn.. i wish someone could figure out what wires lead to that.. so you coud just find a groudn to that.. and maybe it would just work that way???? isn't there some simple way to unhook it from the headlights??? it seeeeems so SIMPLE!!!..
just my car is sooo new.. [only a month old to me.] and im busy with school =(...
#129
#130
#134
Finally got my 06 tsx fogs to work independently of the headlights switch. Not hard to do, but not a job for the novice. You will have to get a seperate rely and another switch. It is the Only way to do it right. The way I rewired it, the fogs will come on with the parking lights, since I used the hot from it to power the second relay. This also means if I leave the fogs on, they will cut off automatcally, when the parking light do.
And also, can you get a second relay from honda?
#136
Originally Posted by Knox
We need a "Rewire for Dummies" diagram because I have no idea what you folks are talking about. I want to do this to my '06 but have no idea where to start.
I re-wired my stock 04 lights, but I took the "easy" or dumber way by just buying a new harness kit with lights so I could use the enclosed switch and could run it with just parking lights or with high beams. Also, if you are wanting just the switch, most Honda dealers sell an 03-03 accord switch for 19-20 bucks which fits perfectly into the knock out.
#137
Originally Posted by Reach
So, where do you get a good oem-fit foglight switch to use for this? eBay turns up nothing good for me.
I just went to the honda dealer to get my switch
#138
[QUOTE=fadinglionhart]Do you have a picture of where to find the "hot" from the parking lights? Or a clearer description on how to use the hot to power the second relay?
And also, can you get a second relay from honda?[/QUOTE
What I did was pull the liner for the right wheel well down. then you can gain access to the parking light wire. Use the same instructions that are used for changing the parking light bulb in your manual. The relay you can get from radio shack, Just ask for an automotive relay. Auto Zone will have them too.
#140
Originally Posted by Scottys11
Do the fog lights go on witht he parking lights on the '07's..i dont have mine yet but they come standard now with fogs...
No, they do not. Only with the headlamps.
#143
soo. what about that parking light theory.. can we do that? splice into the parking lights..
It is not a theory, I had done it.
#144
OK, forgive me cause I'm a visual learner here, but, why is the relay needed?
Seems I could just run the hot line from the parking lights to the switch, then back over to the fog lights and patch into their hot line. No extra grounding necessary, just 2 long cable runs. Of course, hot DC runs always make me nervous. This isn't something I'd do to my car.
dwest it does seem like you've figured out the best setup, i just haven't gotten it into my head how you did it. I gotta come see it sometime and take pics.
#145
#146
I got mine from the honda dealer. If you need some help, let me know. I can probably do it now in under 30min.
#147
It IS the best way. The best part is, if you leave the fogs on, they will cut off by themselves with the regular lights.
#148
I tried to find that relay, but...
1996 TSX. I tried to find those wires under the fog lamp relay under my fuse box in the engine compartment. No luck. Nothing really stood out as the relay or even on the diagram inside the lid. Anybody got any pics of exactly which wires I need to jump for those fog lights to work?
Thanks!
Thanks!
quanaman
01-09-2023 07:33 PM
cycdaniel
12-17-2019 10:58 AM
