exhaust tip bolt broken
Old Mar 7, 2005 | 10:36 PM
leftride's Avatar
i want to ride my bicycle
Question exhaust tip bolt broken
well mark this in the stupid thing to do category. I was taking off my tips to clean them and even after a good spay and soak of wd40 I snapped one of the bolts that holds the tip on. it pretty much sheared it off the head of the bolt and there is only about 1/4" of the bolt is sticking through the other side. The 1/4" isnt really enough to get a hold of so does anyone have an sure fire methods to get the rest of the bolt out. I was planning on getting an EasyOut tomorrow but wanted to get some other opinions. thanks guys.
Old Mar 8, 2005 | 12:00 AM
joerockt's Avatar
Just dial 1911
Wow, that sucks. If you have a dremel tool you might be able to use a cutting disc and put a notch in the bolt. Then take a flat head to it...
Old Mar 8, 2005 | 05:57 PM
xizor's Avatar
Bye TSX, hello domestic?
I did the same thing replacing my tips w/ the OEM body kit. I can't remember what I did but it was a PITA
Old Mar 8, 2005 | 06:01 PM
JeffTSX's Avatar
Subie Tech
Try to see if you can tourch it up than use a pair of vice grips to hold onto whatever is left of the bolt and take it out.
Old Mar 8, 2005 | 09:06 PM
JTso's Avatar
Go to your local hardware store and get an "easyout" bit. Then follow the instructions here....
Old Mar 8, 2005 | 10:38 PM
jlukja's Avatar
that would be the first thing I'd try
Old Mar 13, 2005 | 05:35 PM
leftride's Avatar
Official Results
Dremel Tool: $45
Easy Out: $10
WD-40: $3
damn bolt still stuck in your exhaust tip.....priceless.
well i spent this sunday afternoon trying to get the bold out...the dremel tool worked great for getting a notch in the bolt, but it wouldnt budge. The easy out seemed like it would work too, got it locked in there and I was giving it everything i had....nothing. That damn bolt wouldnt budge. my next option is to get a new tip...hopefully someone has one after an exhaust install.
I am looking for a new tip, i posted in the black market section, but I dont think I am supposed to link to it.
Anyway thanks for you help guys they were both great suggestions!
IBankMouse
Jun 13, 2020 12:53 PM
kev87a
Oct 18, 2015 02:03 AM
joflewbyu2
Oct 8, 2015 11:16 AM
STL TL-S
Sep 23, 2015 08:52 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
