engine gurus
engine gurus
I'm not extremely well versed with engines, but I know a little... and I'm wondering.. the S2000 has a 2.2 liter, 4 banger where our ol TSX is a 2.4 liter, 4 banger... difference is S2000 = 240HP/ 161 lb-ft torque where our TSX is 200HP/166 lb-ft torque...
here is the engine comparison, there are only a FEW differences..
First number is TSX the second the S2000 differences are in bold
2004 Acura TSX 6-speed MT 2004 Honda S2000 6-spd MT
Engine & Transmission
Engine Name 2.4L I4 2.2L I4 TSX wins
Cylinders 4 4
Valves 16 16
Valves Configuration DOHC DOHC
Displacement CC 2354 2157 TSX wins
Bore X Stroke 3.43 X 3.90 3.43 X 3.57 S2000 wins
Compression Ratio 10.5:1 11.0:1 S2000 wins barely
Horsepower 200 240
Horsepower RPM 6800 7800 S2000 wins
Torque Ft. Lbs. 166 161 TSX wins
Torque RPM 4500 6500 S2000 Wins
Fuel System Multi-Port Fuel Injected Multi-Port Fuel Injected
Engine Location Front Front
Driveline Front Wheel Drive Rear Wheel Drive
Transmission Speeds 6 6
Transmission Auto/Manual Manual Manual
Transmission Overdrive Y Y
Final Drive Ratio 4.70 4.10
So I ask you, does the extra RPM and shorter stroke really make the 40 extra HP? Or is the TSX engine's power hiding somewhere
Cylinders 4 4
Valves 16 16
Horsepower 200 240
The RPM capacity is the biggest factor. For example, compare the power outputs of the two engines when both are at 6800 RPM. You'll notice they're a lot closer. After 6800, the TSX engine redlines (at 7100) and the S2000 still has a lot more revs to work with.
Also, cam design and spark timing account for variations in power. There are also variations in the intake manifold design as well as exhaust system design which will account for a small bit of the power.
Plus, the S2000 motor is a different series (engine code is F20C) from the TSX motor (K24A4...I think, please correct me if I'm wrong, folks). These two motors are designed with two different applications in mind so they will have various design characteristics that allow them to better suit their purposes.
Originally posted by TSX Hokie
10 HP of the 40 HP difference between the two engines is due to compression ratio. 4.8% higher compression ratio=4.8% more oxygen molecules=4.8% more power at full throttle.
I thought the same thing originally, but I was wrong so I had to delete that post.
Re: engine gurus
By pure torque numbers the TSX's extra displacement is nearly offset by the S2000's extra compression. So its almost a wash there (161 vs 166).
If the TSX could somehow rev as nearly as high as the S2000, it could easily equal the S2000's HP numbers. The problem is the very long stroke of the TSX makes this veryhard to do, safely.
What would be nice, if we had octane levels to support it, is raise the compression in the TSX and inturn increase its torque. Then maybe slightly increase RPMs.
Re: Re: engine gurus
Originally posted by fdl
....What would be nice, if we had octane levels to support it, is raise the compression in the TSX and inturn increase its torque. Then maybe slightly increase RPMs.
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
STL TL-S
09-23-2015 08:52 PM
