ECU Wiring Diagram
lets just say i was trying to install a i-Vtec controller and messed up something and now my car only goes 25-30 mph and picks up slower then a lawn mower...
T.DoT P.I.M.P. lol
1 Post
Anyways, you should search before you purchase any items because up till now there's NO OTHER ECU piggy-back or tuning for TSX, with the exception of Hondata Reflash, OR, the up coming K-Pro from Hondata.
Good luck, your car will never be the same. Those i-vtec controller is pretty garbage not even the DC5 guys run it.
Is that Lambo door on your TSX????
ok so anyways i undid wat i did and got the diagrams from ACURA so imma mess with that when the weather is good, but for now im looking into this K-Pro thing i dono does any1 know if its gonna work with an 08 automatic...i wanted manual but my dad like you gonna mess up something in it and end up costing thousands of dollars to repair.....so i took what i got....
I Quit
your dad so no manual trans because you'll mess something up, so instead you went and messed up your ECU wiring? way to stick it to the man
If you don't know cars then messing with the ECU is the LAST thing you want to do. Stay and read the forums for a while and you'll see that iVtec controllers don't work on the TSX, you'll also see the only option you have is the hondata reflash, but if you're an 08 AT you are SOL on that and I believe you'll even be SOL on K-pro for an 08 automatic.
SUPRMN84
10-07-2015 09:46 PM
