Dynos with A/F ratio?
Yes, I have. Like I said in the other post, I didn't get a printout of my dyno, but I got ALL the data (including the A/F ratio) from the dyno. I can plot it when I get home tonight.
Photography Nerd
Originally Posted by vwong
Ok...I have to admit. I'm a at this A/F ratio thing (I'm more of a suspension, wheels/tires guy ). What is consider rich and what is consider lean?
wait so this is a stock dyno correct? And you got a max HP of 185.9 and tq of 158.2? Isnt that kinda high considering stoke got 184.6 hp and 151.1 tq? I was jw not trying to be an ass or anything
Photography Nerd
BTW, thanks Dan for the detail explanation. Reading your explanation reminds me of the Internal Combustion Engine class I took back in college. But I have forgotten most of it already.
So, if I'm reading the plot correctly, the TSX burns 6.5% more fuel (14.4 vs. 15.5) at 2000RPM than at 1800RPM? Does that translate into gas mileage being 6.5% better?
Photography Nerd
Mine was dyno'd on a Dynapack, while Stoke was probably on a Dynojet. Dynapack is known to read about 10hp more than a Dynojet, however the dyno's on the Dynapack are repeatable within couple of hp.
Originally Posted by Dan Martin
This AFR chart only measures the ratio under WOT and full load. There are other mappings for cruising speeds so there's not much point to gathering fuel efficency info off this chart.
Here's another question from the . What would happen if I lean out the A/F mixture at WOT? OTOH, what would happen if I add more fuel at WOT?
When I was at Church's place to dyno my Prelude, he said something about my Prelude running a bit lean. But when I compare the A/F ratio graphs between my Prelude and TSX, my Prelude is already running a bit richer than the TSX.
Photography Nerd
I'm not familiar with the use of FPRs for NA engines so I really don't know what they'll do. Usually with a FI engine, an adjustable fuel pressure regulator is used to increase fuel flow when it senses boost. There's a little vacuum line on the top of the regulator that actuates the flow rate.
Maybe Johnny could shed some light on this for you.
The adjustable FPR increases fuel based on load condition via a vacuum line to the intake manifold. When vacuum is high, like during idle or cruising speed, the build-in pressure spring is overcome by the vacuum source and certain amount of fuel is allowed to return back to the fuel tank from the fuel rail. When the vacuum is low, like during acceleration or WOT, the pressure spring is pressed down against the diaphragm forcing more fuel to stay inside the fuel rail causing fuel pressure to go up. The adjustable FPR allows you to adjust the tension of the pressure spring. However, the adjustmet affects the entire rpm range and not just where you need it. Therefore, you might correct certain lean area of the rpm range but cause another area to be rich.
So it functions the same way I guess. It definitely sounds like you want a programable ECU Vincent.
So is it more fuel, more power; or less fuel, more power?
Photography Nerd
That's mighty impressive JTso. It's ruler-flat throughout the run.
Couple questions:
Is datalogging optional or standard on the K-Pro? Do you need a standalone wideband O2 controller or can the K-Pro use a wideband sensor instead of the OEM narrowband?
Couple questions:
cycdaniel
12-17-2019 10:58 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
09-15-2015 06:44 PM
Billu99tl
09-13-2015 11:30 AM
