Different sway bar sizes for Cdn and US models?
I was thinking of getting the Comptech rear sway bar, and did a quick check to see what the stock stabilizer bar sizes are. I was expecting to see the same sizes for my Canadian model as is listed for the US model, but apparently that's not the case!
The US Acura site lists the following sizes:
front: 26.5mm
rear: 14.0mm
The Canadian Acura site lists the following:
front: 25.4mm
rear: 15.0mm
Does anyone know why they'd use different sizes for the Cdn models? With the smaller front bar, would the 22/23mm Comptech bar be too much?
front: 26.5mm
rear: 14.0mm
front: 25.4mm
rear: 15.0mm
Bye TSX, hello domestic?
Re: Different sway bar sizes for Cdn and US models?
front: 26.5mm
rear: 14.0mm
front: 25.4mm
rear: 15.0mm
front: 26.5mm
rear: 14.0mm
front: 25.4mm
rear: 15.0mm
So the CND TSX handles better that the US TSX? Not sure why they would do this but its interesting.
Judging by the Cdn sizes, I'd say the Cdn TSX would be a bit more neutral, but with slightly more body roll (at least in the front). Judging from my experience in the car, it does seem plausible. Of course, I haven't driven a US-spec TSX, so I have nothing to compare against.
1mm diff in front and 1mm diff in back makes a noticable difference.
Registered AssHat
Originally posted by jlukja
More like bulging American waistlines that give the car a higher center of gravity and more prone to lean on corners.
Oh wait...I'm one of them...hehe.
Hmmm, maybe I should hold out on the rear Comptech sway then. Going from a 25.4/15 to a 25.4/22.3 seems pretty extreme...
The neuspeed is 19mm. And they have a front sway you can buy too.
Would going from 14mm to 15mm (US spec to CDN spec) in the rear of a US TSX make any difference?
Yes, but not worth the cost.
Photography Nerd
So what's the score now between US and Canada differences?
Canada Only:
Heated mirrors
DRL's
Washer fluid sensor
Indigo Blue
15mm vs. 14mm rear sway
US Only:
CG
ABP
MSM
Quartz Interior
So we've pulled ahead with a one point lead. :P
Canada Only:
Heated mirrors
DRL's
Washer fluid sensor
Indigo Blue
US Only:
CG
ABP
MSM
Quartz Interior
Photography Nerd
Any place that caries Neuspeed products can get it for you. It won't likely be a stock item at the store but they should be able to get it for you in a couple days. Or try ebay if you want a deal.
a quick question...
for "max handling performace", what sizes of front / rear sway bars should we be looking for?
apparently the aftermarket sway bars are longer the the stock ones, so longer = better!?
Originally posted by Dani
a quick question...
a quick question...
Its not the length , but the width (stiffness) of the bars that affect handling.
As far as better..
well first you need to decide what better is. Do you want understeer? oversteer? how much body roll? For me I'd prefer neutral handling with just a touch of understeer at the very extreme limit. Some people prefer oversteer at the limit.
So wider is not neccesarily = better. You need to tune and balance the front and rear of the car to get it to do what you want. Because most cars have heavy understeer out of the box, the first thing you want to do is thicken up the rear to counter it.
a quick question...
a quick question...
ATCer
Dan-- you forgot that the canadian models also have ebony interior w/ the pearl white.
So the car now has a lot of understeer, how do I "tighten" it up some more. Granted lowering helps, but I like the car to be stiff into a turn.....does that make sense?
Originally posted by Dan Martin
Yes but we can't get milano red with ebony so we'll call it a draw....
or carbon gray with anything
I kAnt Spel guD
front: 26.5mm
rear: 14.0mm
front: 25.4mm
rear: 15.0mm
front: 26.5mm
rear: 14.0mm
front: 25.4mm
rear: 15.0mm
I got the TL type-S sways and strut bar for my Accord all for under 100bucks total, that included bushings and endlinks too.
Nearly 4x less then aftermarket for parts nearly identical maybe even better then aftermarket.
Re: Re: Different sway bar sizes for Cdn and US models?
Originally posted by MrChad
Actually Honda OEM parts like these are cheap.
I kAnt Spel guD
Re: Re: Re: Different sway bar sizes for Cdn and US models?
How easy/cheap would it be to get an OEM euro-r front and rear sway
In addition, do USDM V6-6spd parts fit and/or of simaliar dimensions to the TSX? Maybe bigger rear bars or front if you want more understeer.
I kAnt Spel guD
Originally posted by xizor
I doubt the Accord V6 fits since its a coupe and has different weight qualities with the V6.
The key would be, is the width of the 2 cars close, if so the endlinks should take care of any extra slack. You just need to be sure the bar will clear the exhaust and mate to the bracket holes in the donor car. What I mean is, the bracket holes that bolt the bar to the chassis need to be the same. The bushings in the bracket can differ but the brackets need to bolt up the same. They may since the TSX and 7th gen Accord share the same platform. But it only helps if the Accord has bigger bars or smaller bars to meet your tuning needs.
ATCer
RTR--real time racing? Didn't know they manufactured parts for the public if that's who you are talking about. My list of mods runs with limited companies, spoon being the major one...just my choice.
joflewbyu2
10-08-2015 11:16 AM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
MonkeyTrucker
09-21-2015 06:15 PM
