DBW with K-Pro Update!
#121
Rep'n Taxbrain.com
From his sig:
2004 Milano Red TSX 6speed
Navigation
Injen CAI
DC Header *broken
Hondata Heatshield
Hondata Reflash
Comptech Rear Stabilizer
Tein Flex Coilovers
Ingalls Rear Camber Kit
Ingalls ETD
Comptech Short Shifter
Brass Shift Cable Bushings
Exedy Stage 2 Clutch
Exedy Lightweight Flywheel
Best 60' - 2.2 *to date*
Best 1/4 - 14.9 *to date*
Navigation
Injen CAI
DC Header *broken
Hondata Heatshield
Hondata Reflash
Tein Flex Coilovers
Ingalls ETD
#123
Special-K
Originally Posted by feuss2
When is the harness coming in?
#125
I don't get why we can't just run a piggyback computer thats less complicated than this, I was reading about the procede chip for the bmw 335i and its a simple plug in and play since it receives the signals from the factory ecu, recalibrates it, then sends it to the engine, and the entire car still has complete driveability. Cept those procede guys pulled another 100hp and 100ft/lb of torque out of the stock engine/turbos. I'm surprised greddy or HKS hasn't discovered something for us.
#126
The only problem I have with Hondata is that because they have a monopoly, they tend to be less forthcoming with information. If they were competing with another company or group, I'm sure that would be spur them to be a little more consumer oriented.
#127
Originally Posted by CarbonGray Earl
Honda has always been more complicated and more secretive about their ECU programming. For as popular as Honda's have been, were lucky to have Doug and Hondata.
Honestly though, the secrecy behind Honda's ECU is not neccessary. If consumers knew of tuning potential on the Honda/Acura cars, I'm sure the market would broaden. What have they got to lose if tuners crack the ECU and turbo a TSX? (Just an example) Other people will just be thinking "wow thats a nice car, maybe I might consider doing that" I really can't see a downside for Honda to allowing people to modify their cars.
#129
Drives With Hands
Sharing info on this forum is really important... I've considered doing some reconditioning to the MAP sensor input and AIT input. I may just relocated the AIT sensor and see how that goes... I'm OOW anyway!
#130
10001110101
I will try extending the wires and locating it down by the fog light cover area... If its farther away from the heat, the faster response time won't be as much of an issue. I think most sensors would have simiar charactaristics. Taking the plastic off the oem part could make it respond faster, but that also protects it from damage...
#131
10001110101
If your interested in relocating the AIT, see this thread:
https://acurazine.com/forums/showthread.php?p=757711
We'll keep this one related to DBW w/ K-Pro...
#135
Originally Posted by LukeaTron
600hp?! What does he have a bigger turbo than his motor?
k24/a2, gt35r, kpro, 91 pump gas at 15psi..with all accessories and 18" wheel
#137
Special-K
[QUOTE=r32creepr]not really..and i am cstyleaccord..by the way those kpro harness are built by me
Whats with that dip in torque??
#138
where is my garage?!
1 Post
so if you made that harness to be compatible with the TSX and k-pro, what would one expect as far as fuctionality? would a TSX owner have full k-pro functionality along with use of all gauges and the normal car amenities (A/C, VSA, cruise control, etc...)?
also, how long does it take for you to usually complete the harness?
#140
Originally Posted by r32creepr
also i might be making harness for tsx/kpro..a friend has a tsx.just need to find a time for him to bring the car by so i can test it to make sure everything work properly
Keep these guys informed if you could.
One question: Is your accord a manual or auto?
#141
T.DoT P.I.M.P. lol
1 Post
Awesome, I was the one who mentioned your Accord. Read it while I was lurking over at the Accord forum. Great work.
#142
Originally Posted by chuson
K-Pro only works for Manual as I know, but if the harness does work w/ Auto, that will be great... I hope I'm not too positive.
I think this guys was auto as well, but I am in no way certain.
Like you said, it would be great.
#143
Rep'n Taxbrain.com
#144
PrecyseStylez: the tq dip is due to tq jump..dyno couldn't read it fast enough or something..that what my tuner said..so the dyno saw it as a drop instead. but that dyno graph should have shown higher tq number. and the car actually made to around 590whp when it was running smooth. i don't have that graph..tuner has it..and forgot to email it to me..
xjohnkdoex: yes you will be able to obtain all the function of the tsx. gauges, climate control etc. however vsa is a tricky function i have to look more into it. but i believe it shouldn't be a problem. we have talked to hondata before and Dough said if it will work, vsa might not work..so i'll have to dig more informatino. the harness itself takes me about a few days to make one. i do it on my spare time.
CarbonGray Earl: my car is manual..auto tranny would have been blown by now.
chuson: sure if you read it on hondata website. it has been proven that it can work in an auto. there was one rsx guy with an auto and he got it to work..he made a harness similar to mine. i am actually building harness for accord people with auto tranny right now. should see how it turns out in a few days.
Tsx536: i'm from oregon
#145
1 Post
ah cripes, i have an auto.
obviously, the auto tranny can't withstand that much HP. but it could be done if you lowered the boost and made sure the engine could withstand it? or can it not be done at all?
#149
T.DoT P.I.M.P. lol
1 Post
This will be a GREAT break-thru if the harness work, and why wouldn't Hondata invest their time/money to produce it.
#150
1 Post
bump: are there any updates regarding this harness?
#151
Time to Climb
I'm not too concern about the Auto tranny, because I've got a reliable sources for "beef-up" torque convertor for us 5AT. The only thing that matters now is the Engine management.
#156
Special-K
Yea... its a back and forth battle with hytech in getting this damn harness! They arent the ones who made the harness so "John" has to wait on the harness tech for answers... So if he waits then i have to wait.. I was talking with the one guy that posted the Dyno sheet of his Accord Turbo.. I was gonna try to meet up with him in Maryland and i gave him my number and everything but he never called me. He was gonna take a look at the TSX ecu and see if he could make the harness like how he did for his Accord.. So i guess i'll wait!..haha
#157
One thing this forum has taught me is to never buy anything from Hytech, no matter how awesome their stuff is. It may be awesome, but you'll never have it.
#158
T.DoT P.I.M.P. lol
1 Post
Race car is their main priority, I guess that's where the $$$ come from too.
#159
A DiRTBAG decal on my
Thats not completely true! You WILL get it, eventually! Good things come to those who wait!
Keep it mind, these are hand made, NOT mass made.
Yes race teams are his priority.
#160
1 Post
kind of related, so this guy over on k-series.com has a 7th gen AT V6 accord and was trying to get k-pro to run on it with some bolt-on mods. he got it to work.
the interesting tidbit-hondata may have a prototype harness that may or may not be released that works with DBW.
a lot of may's, but check the post out yourself, and i'll leave the conjecture to you guys.
LINK
"Thought I just chime in and say kpro works 100% now. I met doug from hondata and he was telling me how he has a prototype harness that may or may not be released that may work with DBW. Lots of "mays" i guess. I gained 30+ whp from stock on a dynapack so that translates to something like 20 or so i guess on a jet. This is not with the cams and such. Only a basic tune and boltons!
Here's the Dyno and video"
LINK
