Comptech short shift and metal bushings installed
A-spec Arctic Blue
Again, thanks to Jtso for helping me install the Comptech short shift and metal bushings. I love the shorter and more precise throws. For anyone who owns a 6MT, it is definitely a great mod for little money. I only paid $42 for the short shift and $17 for the metal bushings from ClubRSX. The metal bushings are a nice addition since it allows the shifts to be nice and tight with very little give. Jtso followed the Neuspeed instructions and it took much less time. It is much easier since you don't have to take apart the shifter once you get the center console removed.
Comparison between stock and metal bushings
A-spec Arctic Blue
Originally Posted by TSX Cman
what do th metal bushings do for you, i have the comptech in, and i need it to feel tighter and have less movement (not shifting movment)
"What they do is replace rubber with metal. This means that when you shift now there is flex because the rubber is soft. With the metal it takes away the flex so your shift is smoother and cleaner."
Bye TSX, hello domestic?
look for the link to kurt bradley's friend in the original post about metal shifter bushings. i'm very sure he can sell them for cheaper than clubrsx
I've got them in my cars.
wouldnt the metal bushing needs to be lubricated to make sure it moves smoothly or is the metal bushing is acting like a bearing type of bushing .. someone kind to elaborate on the the metal bushing besides it reduces flex?
A-spec Arctic Blue
hey what's that metal plate looking thing that came with the comptech short shifter?
I installed my neuspeed short shifter and metal bushings during the summer and I love it. Funny how they just don't make it this short from the factory. After installing it in my TSX, i believe this is a must have for any future car of mine.
A-spec Arctic Blue
Need some help to install my short shifter!
I managed to get all the way to the shifter housing. But I'm having trouble in removing the shifter cables (including the clamp). Do you just yank out the clamp or is there a special trick to do that? What about the shifter lever housing? Do you have to turn it in order to remove it?
Finally got it done. But I still have one question.
It seems like I can never screw the short shifter hard enough to the stock shifter. As a result, the stick seems to be wobbling. One thing I know I've missed was applying the Loctite stuff, which I will redo it later. But will this alone fix the problem?
A-spec Arctic Blue
Originally Posted by AZTSX
mine wobbles too but i have applied the loctite already i do not know if it is supposed to be "wobbly"
I thought I did try to push it down as far as possible, but maybe not enough. I'll have to try it again. So, you guys are saying the screws should be flush with the short shifter if it's installed properly and the ball on the stock shifter should have passed the screws, right?
A-spec Arctic Blue
Originally Posted by JTso
Make sure you back out the set screws far enough to clear the stock shifter. Otherwise, it's not going to go in. Once the shifter is in place, you should be able to tighten the set screws leaving about 1mm thread exposed on the outside.
ive noticed i have had to push a lil harder than before to get into reverse is this normal or should i be worried alsothe loctite wont be an issue for the set screws correct?
Yeeha! I finially got it done properly after taking the center consol apart 3 times. I think I'm becoming a pro in doing this. And thanks to you guys for the tips on using the Neuspeed instruction instead. It is really easier!
Seen many tips of using the Neuspeed instructions. How permanent is the loc-tite? How necessary is it? Would it make it much more difficult/impossible to remove the Comptech in the future if the need arose? What I am getting at is, the Neuspeed instructions don't mention using it, and I'm betting their shifter is pretty much exactly the same as the Comptech (from the pictures I've seen anyway), so would it be a big problem if I skipped that step?
Thanks for the input.
A-spec Arctic Blue
cycdaniel
12-17-2019 10:58 AM
asahrts
09-04-2015 05:55 PM
