Comptech modified high flow injectors
It looks like Comptech has the high flow injectors available, which means SC boost upgrade kit in the future and possibly moving the rpm redline back up. It might even be possible to eliminate the FPR modification step as well.
http://www.comptechusa.com/store/product422.html
Originally Posted by dingobiatch
wait, SC upgrade kit? I'm so dumb, I've been worried about if I get a SC, and then Comptech releases a better kit, then I would have to repurchase it. How much do you guys think upgrades will be?
I talked to Billy when I was at Comptech on Friday about the Stage 2 kit and they aren't quite ready to work on it yet. I believe they are going to working on the SC kit for the 2005 TSX MT next. They also have a few other prototype parts that they are experimenting with.
If we really wanted to go Stage 2, we might be able to push for one though. They already have the injectors and pulleys available since the RSX kit uses the same ones. The only thing missing is a reflash/tune by Hondata to handle the new injectors and higher boost. If only we had K-Pro
Based on the pricing for the RSX kit it would be $700 if you bought it alone, or $399 if you bought it with the SC kit at the same time.
http://www.comptechusa.com/store/product314.html
https://acurazine.com/forums/showthread.php?t=26580
Anyway, it spells more power.
Originally Posted by Dan Martin
Typically companies don't like to give things away, so yes, if they come up with a higher boost option, then likely they'll want some money for it.
Originally Posted by moda_way
I mentioned this a while ago, Nov. 9, 2005.
Originally Posted by jmathew34
anyone ever figure out the duty-cycle of the stock injectors?
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
