You think the TSX is less expensive to maintain than the TL?
yesterday, i had to go to acura to buy a trunk tray and i saw a nice colored new TL outside, i think it was anarchite (looked like a graphite grey), why didn't they give that color to the TSX?
anyways, i asked a service guy what would be more expensive to maintain and he gave me 2 service brochures for the TL and TSX and it seems you have to change the oil on the TL recommended at 3750, while our TSX is at 5000?
I'm only at 3800km on my TSX, but when I go for my first oil change I was thinking of going synthetic and maintaining that. Do you guys think it's worth it to go synthetic on the TSX or just stay with normal oil?
Stick with mineral oil and change your oil under normal service recommendations unless you really qualify for severe conditions. I change my oil every 10000km.
Synthetic is a waste of money. I would use it only if outside temperature was constantly under -25 deg.
With respect to the TSX, I can perform all of the routine maintenance myself. That's not to say I will. I may not have the time but it's easy enough that I can perform it. The TL, however, has a timing belt, not a chain like the TSX and the risk-reward ratio is such that I won't do a timing belt change on an interference motor. As is typical for late-model Honda V6s the timing belt and accessory belt change probably requires removing the right-side motor mount.
The TSX maintenance schedule recommends oil changes every 10,000 miles and oil filter changes every 20,000 miles. The TSX shop manual defines "Severe Conditions" as use including "such as a taxi or commercial delivery vehicle".
Even in the NYC area, I don't really meet the "severe use" definition. However, I still plan to follow the 5,000 mile interval for both oil and filters, and to use synthetic oil because I expect a car to last reasonably close to 200,000 miles.
I've used synthetic oil and 5,000 mile oil change intervals on my '98 Volvo T5 which has close to 140,000 miles on the clock. It still uses absolutely no oil between oil changes. The Volvo inline 5 has something of a reputation as an oil burner, but not mine.
The TSX engine block assembly lists for $3898.96 and the cylinder head assembly for $3978.32.
For an extra $300 for every 100,000 miles I think this is cheap insurance. I use synthetic oil in my wife's Oddy and in all my lawn equipment now, too.
The main things that I can think of that would vary would be brake pads. The heavier and heavier engine TL would probably use more pads than a lighter more weight balanced TSX. Of course all drivers vary so this depends on how you abuse your brakes.
The oil changes are yet to be known since we don't know either car will respond throughout the life of its motor. If its your typical Honda motor though their shouldn't be much of a difference.
Are the lights the same for both. I know both are HIDs but are they from the same supplier and the same parts/assembly?
Tires is another maintenance issue with the cars. They of course will be affected by driving behavior, mods (if any), and amount of rotation. I'm not sure if TSX's and TL's (with 17s) have the same tires but that should be looked at too.
50% more cylinders means that any spark plug/valve/piston work will cost 50% more for the TL. Brake pads of course will wear out faster on the heavier TL, like Doom said. Everything else should cost the said between the two cars.
I know I forgot something. More spark plugs. Plus on the TSX it'll be 125225x easier. On my Accord it takes a while to change for the back ones since they are hard to reach.
Would a valve adjustment cost more since it might be more difficult, or does Acura (if you use them) charge a standard fee?
I don't see piston work as regular maintenance. Maybe a fun upgrade.
Originally posted by Dan Martin
Canadian cars are supposed to follow the severe duty so you should be changing your oil at 8000. Dealers will refuse engine work if you don't follow the severe duty schedule in Canada.
If it was so, why do you think that they included both schedules in the maintenance manual FOR CANADA?
The only mandatory maintenance considered 'severe' (as mentionned in my booklet for my Accord) is the change of the timing belt every 96000km instead of 168000km. It is explicitely written.
Re: You think the TSX is less expensive to maintain than the TL?
Of course, the TSX is cheaper! :P
is the RSX cheaper in insurance than the TSX?
i think it is higher because it is considered a sports car.
Disingenuous:
Main Entry: dis·in·gen·u·ous
Pronunciation: "di-s&n-'jen-y&-w&s
Function: adjective
: lacking in candor; also : giving a false appearance of simple frankness : CALCULATING
- dis·in·gen·u·ous·ly adverb
- dis·in·gen·u·ous·ness noun
An RSX will TOTALLY be different in insurance. Considering the percentage of drivers that total those or get parts stolen. I don't really consider insurance cost of maintenance per se. More like an additional expense.
Originally posted by AZTSX
ne one drive the tl lately? are the brakes better in the tl cuz i know they are really sensitive my bro has one and i barely have to tap it to come to a stop jw? thx
Originally posted by C_TSX_Go
so I get LSD Brembo brakes and those suckers stop about 30-50 ft sooner
W/o using ABS, I'm sure you could tell a difference. Honda brakes are not very effective. My Jetta's brakes were much better (when not using ABS).
Originally posted by fdl
Ya that makes more sense. Its weird how some reviewers come out of left field with their comments.
Dan Martin, as I said my car is an Accord and I don't have this note (just checked in the manual). But if it is specified as in the TSX manual, I wouldn't argue long and follow the severe schedule of course.
driving in areas using road salt or other corrosive material;
driving on rough road
(extracted from Honda maintenance manual)
I recommend Mobil 1 for any high-revving 4 cylinder engine. You will get better lubrication on cold starts in the winter, reduced oil consumption at high rpms at any time of year, and less friction than conventional oil. I get my oil changed at the Acura dealer, every 5000 miles.
emailnatec
29
09-28-2018 04:27 PM
GWEEDOspeedo
01-15-2016 10:39 PM
STL TL-S
09-23-2015 08:52 PM
4drviper
09-23-2015 07:42 PM
2004, acura, acuras, brakes, center, engine, expensive, insurance, interference, maintain, maintaining, maintenance, mobil, replacement, rsx, service, tl, tsx
