When is fuel cut?
When is fuel cut?
I hit 7250 RPM this morning (not totally on purpose), and didn't feel any fuel-cut "hesitation" or whatever you like to call it. Is FC at a really high RPM or what? I'm kinda .... but
I've found the fuel cutoff point is at about 7400 RPMS..
Granted, I hit it that one time on purpose.
What kind of damage can this do to your car if you hit this point often?
J.
P.S. When I rev my engine in neutral it cuts off at a much lower point. Can this damage your engine as well?
J.
Revving your engine with no load is much more dangerous than with a load (the inertial forces aren't balanced by combustion pressure). I think that's why they put that lower no-load fuel cut in.
Wow. 7400? I'll take your word for it.
J.
J.
some where right after the redline. i've did it in the 3rd way too many times, coz there is where the sweetest power band of the car is. you get this quick burst of power right after 6000rpm where the vtec kicks in but unfortunately ends very soon at redline cutoff. (which really pisses me off... )
also, i found out that if you downshift too early. The fuel gets cut off until it's below the red line. it scared the hell out of me the first time. I was going into a high speed corner some where around 5000rpm in 4th. I hit the brake, hit the clutch, give it a litl more gas to go into 3rd. After i release the clutch, NOTHING!! No throttle control into a corner!! Then I see the rpm needle falling slowly from above the redline but no power to the car at all. and right after the redline, you get this sudden push as if someone just kicked you in the back. now i am more careful about that 4 to 3 shift but it's so annoying when you are driving "a litl" agreesively. i will be the first to get inline if some company can reflash the ECU to get 1k more rev to the cut off.
Ahhh, high red-lines. I would tap 8100 in my GS-R all the time. Those were the days. Hitting 8000RPM's became addicting, the sound was so sweet I just could'nt resist.
And 8400+ in Type R test drives.
Originally posted by Lung Fu Mo Shi
I'm sure of the exact specs, but let's just say, "go straight to jail" speeds.
I have taken the steps to go to a high speed ring we have here in Quebec to really go all out with the TSX. This ring allows for 300+ kph (190mph), so if it works out I should be able to give you the numbers. I just expect there is no speed cutoff, only drag limited, and it should be in the whereabouts of 235-240kph.
Many people have blown up their engines because of this. There's actually an RSX video on the net of some guy going from 3rd gear redline to 2nd by accident..and let me tell you a fuel cutoff wouldnt make a bit of difference. So i dont see any point to the TSX doing, plus I dont see why you would ever be in a situation where you would want to shift like this.
Originally posted by sauceman
You are pretty right.
Originally posted by fdl
Are you saying that if you downshift so that your rpms will be past redline..the fuel will cutoff? Why would you want to downshift into that high of an rpm? If you do that you could easily cause damage to your engine...fuel cutoff or not. But I've never heard of a car doing this before, and really it would be completely pointless as it wouldnt prevent damage to the engine. The engine will still spin at that rpm for that speed/gear once you let off the clutch.... Its purely mechanical.
Fuel cut is going to do dick all for you if your wheels are spinning the engine past redline.
Originally posted by Dan Martin
Ahh the money shift!!! Great fun to watch!
Originally posted by TSXautoXer
I saw a video (equipe rapide autox), a BMW M coupe mishifted, grind the gear, overrev the engine, spun but manage to go on, and then he accidentally hit reverse...I'll let you guy's imaginationn to do the rest....
1) I hit the brake, rpm drops
2) step on clutch, match the rev, downshift to 3rd(so i can get enough power to play through the corner if i need it)
3) drive through the corner with as much throttle as the car can handle without going sideways(too much).
and for some reason, it very easy to over rev the engine when i do the 4->3 shift.
I know all about the RSX-S blown trannys since i had the one of the 1st in town and was part of the clubrsx thing for the short period of time i own the car. I almost blown the engine twice, but it was mis-shift, not a regular downshift. I was lucky enough to feel the weirdness on clutch before i let it go completely. ppl were redlining 3rd, mis-shift to 2nd instead of 4th. And one of my friend/customer was one of the first victim when Acura decided they are not going to warranty situation like this(they paid for the first few incidents in north america). My case with the TSX is diff.
btw, i tried to brake a litl more before to avoid the situation at the same corner. I tried to keep the gear in 4th all the way through, but the rpm was too low when i get back on to the gas and it takes too long for the car to get back to it's power band, and the car feels kind of unsure.
also, most ppl wont drive this way on public roads and i wont recommend you to try either.
what the corner looks like:
But isn't reverse on europeans at the extreme left of 1st gear? Isn't it really difficult to mistakingly hit reverse with that sort of a setup?
best explanation i can think of is his shifter/transmission was xxxked.
Interesting. The only thing I might caution you about is that it may be electronically limited to 150-155 mph like other cars (old Toyota Supras). When I read a magazine review of the Supra they said they hit the 155mph fuel cut off and it damn near threw them through the window.
Aric, be careful!
You could cause your front wheels to skid out of control with the
engine over-revved. Exit, stage left as they say!
You either need to jab the brake harder and get your speed
below the limiter before 3rd or stick it out in 4th.
Also, the financial damage from ruining your engine is not fun either. Happy driving!
A couple of things.
The M Coupe driver who shifted into reverse was doing an autocross at the time and assumedly was trying to shift into first for a slow turn (as you would). As an M Coupe owner myself I can tell you that you really do have to shove the shifter hard towards you to get it in reverse, but one would assume in the heat of the moment he just got carried away. I don't believe there was any other misshift or over rev involved. I have no idea what damage it caused, if any.
Secondly, there are two ways to overrev. One way is when going up through the gears though in most cases a fuel cutout will prevent damage. I don't think you will break anything bouncing off the limiter. If it causes an unpleasant loss of power then you may want to mostly avoid it (some cars have kind of a soft limiter). The "money shift" is caused by downshifting to the wrong gear (or in some cases, the right gear but at too high a speed). Generally slamming the car into second rather than fourth, or third rather than fifth. It is not incredibly easy to do, and generally means you are manhandling the shifter. If you don't realize what you've done before you let your clutch out you WILL destroy your motor (on many performance type cars). I actually got away with it once slamming a car back into 1st when aiming for 3rd (don't ask, it was 15 years ago). The car was not a performance car and though the noise and the rapid deceleration was scary the car was fine. I know I wouldn't be so lucky now.
C.
C.
mlody
12-04-2019 02:11 PM
joflewbyu2
08-18-2019 10:38 PM
joflewbyu2
10-08-2015 11:16 AM
polish_pat
09-25-2015 12:24 PM
