When does the low oil light turn on???
how little oil do you have to have to trigger the low oil level light on the gauges? does it keep the engine safe and makes sure your oil level is normal? or should you check the oil level yourself ?
tomshu4279 (08-18-2014)
Check it yourslf. if the light comes on, it's usually too late
ABP TSX
Originally Posted by eviljai
mine comes on pretty early. usually after the light is on, i still have about 4-5 gallons of gas in there. But ya knoe, try not to always use the bottom end of the fuel
I can't speak for the TSX, but based upon other cars I've had the light goes on when it's pretty much out of oil. By that time, the engine is basically screwed. Best to check it yourself and be aware of any oil spots in your garage/driveway (if you have either.)
TSX: Boeing Dreamliner!
??? Okay, are we taking about oil or fuel.
Fuel....I find I have burned about 50L (??gallons) when the yellow light comes on.
If your talking about oil.....then.....you have seconds to go before before a major failure in most cases. I'm not sure if the TSX has a low oil level (as opposed to pressure) indicator built into this red light on the instrument panel. Honestly, a 9 year could check the oil in this car.....bright orange dipstick, make sure engine is cold and see that its near the higher point on the stick. Do not rely on sensors for your oil - check it yourself or you will pay a humilating consequence.
Originally Posted by sauceman
When the oil light goes up, it`s too late. You are missing at least 2½ qts. Not too good.
But it will come on with really low oil because low oil means that there's not enough oil pressure.
mada51589
05-03-2022 08:54 PM
HeloDown
09-08-2015 06:51 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
