When Do I Need To Replace My Battery?
I own a TSX'04. I recently installed my usa-spec and during the installation my battery died. now it feels like the car starts uneasily and takes longer time for ignition. mine is running 65k km and i'm thinking it might be the battery.
could you recommend me some replacement batteries and the costs?
I can't find my garage
could you recommend me some replacement batteries and the costs?![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Driver/Detailer
You don't need a DIY for replacing batteries! Just take the -ve terminal off, then the +ve terminal. Remove the battery tie down and lift the battery up. Reverse the order to install your new battery.
Just get any good high CCA sealed battery. I'm using an ACDelco.
Originally Posted by aaronng
Go aftermarket battery for sure. The OEM one is poor.
Interstate Battery dealers and most Honda/Acura dealers have a tester that will estimate the life of your current battery.
I have an Optima battery in all my cars.
I guess guess your "search" button was broken....
https://acurazine.com/forums/showthr...hlight=battery
in the 24th and a half...
Originally Posted by LoveMyTSX
Optima Yellow FTW
Make a hole, coming thru!
Consumer Reports did a comparison of batteries. Napa, Duralast, AC Delco, Interstate scored well. Kirkland (Costco house brand) was considered a good value. October 2006 ish if you wanna catch it at the library.
My car was a week old and put the Yellow Top 51R in it.
The OEM battery is what should go into a f***ing Yugo not a $30K Acura.
I'm not that mad. At least Honda decides to cut the cost where it can easily be taken care of by the aftermarket scene. Unlike Ford who cheaps out on core elements like the transmission and cooling system.
The size of the battery in the TSX is used in the Mazda 121! The previous JDM Accords used a larger battery.
Let me help you!
yeah but which ones though? is there a DIY for replacing batteries? ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
As mentioned before, you just have to remove the battery holder and the two cables. After that, you can lift the battery. Be careful, car batteries are usually heavy.
I could be wrong, but if you get one and replace it yourself, ask about where to turn in your old battery for recycling/disposal.
Originally Posted by timd38
Anyone that sells batteries has to take the old one. It doesn't matter were you bought it. Lead is $1.50 a pound, so plenty of people want them.
Originally Posted by DuckDodgers
And most of those places levy a "core" charge that is refunded when you bring in an old battery...
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
Any Acura dealer will take the "core" back. Acura of Cerritos (for example) will give you $9 for it.
New Consumer Reports
As I recall, the review results were similar to the one David remembers from last year. Optima is included.
Last month I replaced my OE battery. The service life was a bit disappointing. I have about 17K miles and the car makes 4 years in December. Went with a Kirkland 51R for $46 and so far no complaints. Costco also refunded the core charge of $5 when I returned the old battery. The Optimas are better batteries but come with a premium price. The Kirkland specs and warranty are comparable to Duralast, Diehard and others at almost half the cost. They're worth looking into.
Driver/Detailer
Battery life is based on years, not miles. And for a low mileage car like yours, battery life will be shortened because of the shorter charging duration for each start.
oem battery is crap. Just had my front speakers replaced and added a new amp. playing music in my car for about 20 minutes or some times less than 10 minutes with the motor off, the battery dies out. I had to jump start my car about 4-5 times already.
![Rave](https://acurazine.com/forums/images/smilies/trance.gif)
Driver/Detailer
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
