What RPM are you at for 85mph?
Originally Posted by Doom878
Just curious since I might like the TSX in a couple of years. Does it get buzzy on the highway?
Originally Posted by jlukja
I didn't really pay attention to the RPMs (soemwhere north of 3500 I think) but it doesn't get buzzy at all. Also, I have the AT, the MT RPMs will be a little higher at 85.
When you're in 6th gear and cruising above 70MPH, the RPM needle is at the same spot the MPH needle is at. (Or very close)
70MPH - 135 degrees (Obtuse) - 3000 RPM (Give or take 100 RPM)
80MPH - 115 degrees - 3500 RPM.
Moderator Alumnus
Originally Posted by slo007
Why won't the smilies show up??
Just be happy AZ is back online. Soopa could have kept it down until it was all fixed..
I thought you weren't going to post till the colors change.
Why would the RPM on the 6mt be higher than the 5a? Wouldn't the extra gear ratio give you a really nice low cruising rpm?
Originally Posted by sauceman
In case you didn't notice, the site has been almost completely rebuilt, so we need to give some time for all the issues to be looked upon.
Kick Ass Duke
MT AT
1st 3.27 2.65
2nd 1.88 1.52
3rd 1.36 1.08
4th 1.03 0.77
5th 0.83 0.57
6th 0.66
Final 4.76 4.44
also one thing i would like to add about gearing and the TSX, i live at 6500 feet above sealevel. for thoes of you who dont really know the effects of elevation let me state that our 1/4 times increase by about 1.25-1.5 seconds. we loose about 25% of the HP at this elevation
anyway my TSX 6MT still has enough balls in 6th gear to climb up about a 10% grade and maintain the 80 mph speed. in fact if i start this 2 mile grade at the bottom doing 80 at full throttle i can be doing nearly 100 by the top of the hill without downshifting.
even with as much gearing as the top gears of the TSX has there is still plenty of power on tap.
Engineer
Originally Posted by Tsx536
I also have 5AT. I'm at about 2800-2900 at 85.
yup sounds right...
Originally Posted by joerockt
Yea, around 3500K. Not too buzzy, but the nice thing about this is you really dont have to downshift to get good pick up for normal passing and whatnot.
6MT of course
6MT of course
DerrickW
11-15-2015 05:52 PM
