VSS - Vehicle Speed Sensor
Old Jun 27, 2005 | 09:09 AM
eschamp's Avatar
TSX AT
Where are the electrical connections to the VSS? I couldn't find anything in the service manual.
(I'm looking to connect a tripmeter.)
Old Jun 27, 2005 | 09:16 AM
moda_way's Avatar
The car has a trip meter already or am I mistaken in what you want to do.
Old Jun 27, 2005 | 09:17 AM
Motohip's Avatar
I'm a llama :(
That's what I thought too.
Old Jun 27, 2005 | 10:18 AM
eschamp's Avatar
TSX AT
The tripmeter in the TSX -- probably in all "digital" cars -- is no good for rallying (not WRC type rallying; USA type) because we need something that will measure and display to the hundredths or even thousandths of a mile.
Perhaps I should have said that I want to install a "rally computer".
Old Jun 27, 2005 | 10:19 AM
elduderino's Avatar
VP Electricity
Look in AV for "AVIC VSS". The Pioneer AVIC nav needs that wire and there are some threads about it.
Old Jun 27, 2005 | 11:12 AM
eschamp's Avatar
TSX AT
I don't have the nav system -- boy, would a rally computer be a welcome addition to that! Doesn't the speedo get its speed info from the VSS??
Old Jun 27, 2005 | 12:08 PM
glacius's Avatar
What's a 70 year old doing rally racing? You should stick to driving to the grocery store and back..
Old Jun 27, 2005 | 12:13 PM
elduderino's Avatar
VP Electricity
Neither did these guys. It's an aftermarket system they were adding. They needed the VSS wire to do it. I think it's in the DIY Master sticky thread at the top of the AV section.
elduderino's Avatar
VP Electricity
Oh, and the speedo gets its info from the CAN bus.
Old Jun 27, 2005 | 12:19 PM
eschamp's Avatar
TSX AT
Hey, buddy? Can't you read? I said NOT WTC TYPE RALLYING. US rallies are not races. Do you want to try to beat me on an autocross course?
Besides, you should see the route I take to the grocery store!!;-)
Old Jun 27, 2005 | 12:24 PM
Tsx536's Avatar
Rep'n Taxbrain.com
I have my Pioneer N1 hooked up to the VSS wire. Let me dig up the thread with the info.
Do you have navi or non-navi?
The non-navi version does not have this wire, so you'll have to insert it into the harness yourself.
Edit: Here you go.
https://acurazine.com/forums/showthr...t=case+missing
Old Jun 27, 2005 | 12:29 PM
eschamp's Avatar
TSX AT
Are you referring to the Audio & Video Forum of the AcuraZine Community? Couldn't find "AVIC VSS" there -- it didn't like "VSS".
Old Jun 27, 2005 | 12:34 PM
eschamp's Avatar
TSX AT
Edit: Here you go.
So you're saying that the signal is there at the connector but I have to plug in my own wire? What kind of male connector shall I use?
What connector is that and where is it located?
Thanks.
NJIT, eh? What major?
Old Jun 27, 2005 | 12:59 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Actually, I didn't use a pin. What I did was just strip the wire, then insert it into the harness. Then I put silicone on the outside to seal the gap and make the wire stick to the harness.
When you're looking at the ECU from the passenger side, I believe that it was the harness on the far right. Just take a look at the pin layout pictured in the thread I linked you to. Make sure that everything lines up.
I'm a computer science major, that's not my website though.
Old Jun 27, 2005 | 03:42 PM
eschamp's Avatar
TSX AT
OK, thanks.
Old Jun 27, 2005 | 09:42 PM
SWRT's Avatar
AutoX'er
Don't use your VSP signal, with a 2WD rally car you have the luxury of two non-drive wheels that can hold distance pretty acurately. VSP signal comes off the transmission... it won't account for wheel spin and you'll have artificially high distances. If you use your rear ABS sensor, you get the waveform your computer needs and its dead nuts acurate.
Who am I kidding... you guys aren't hitting the gravel in TSX's are you!?
If wheel spin isn't an issue the VSP signal should do, but you have to grab it before it gets to the engine ECU... after that its in the CAN bus and you can't get it unless you have a CAN analyser... which isn't cheap... or worth it just for VSP.
-SWRT
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
BadassAcuraCl
1G CL Problems & Fixes
Sep 14, 2016 03:26 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
DS2000TL
Sep 9, 2015 09:26 PM
