TSUX: Center Console Instruments Go Black
So I'm driving home from Costco today... having had an epiphany today in class. My epiphany was that I really loved my car and I was really happy I bought a Honda.
So I get in the car and turn on the headlights and wipers... because it's dark and raining. Imagine my shock when I look over and my radio can't be seen. Furthermore, imagine my shock when I see that my climate control and clock cannot be seen either.
So I pull over and take a look. The climate control can barely be read... I can only see the bottom half of the TEMP characters... looks just like a broken LCD screen on a calculator or something. But this is on all three instruments! They're all dead! WTF IS THAT.
Re: TSUX: Center Console Instruments Go Black
1. You have the brightness dial turned way down.
2. Your car is screwed. Weren't you having gas mileage problems back in the day also?
If #1 isn't the problem, I'd get that car checked out.
Doesn't sound like something as simple as being off, if he sees the bottom half of the LCD displays. But it sounds unlikely that all three would screw up like this at once. Maybe there's something wrong with the fuse and they aren't getting enough voltage? Just take it in and find out for us...
Originally posted by MikeL
Have you tried holding the CD/Aux button down for five to ten seconds? When I do that on my car the clock, climate control, and radio go dark too. Doing the reverse turns them back on.
Good luck!
Good luck!
Good luck!
Good luck!
OK now that it's daylight I can see clearly what's going on.
The clock, radio and climate control are all visible. However they are only BARELY visible to the point where you have to get really close and you can BARELY make out the numbers. I tried holding down the CD/AUX button for 5 seconds... and it beeped but nothing changed. Held it down again for another 5 seconds... another beep but no change.
Looks like I'm going to have to take it in... for this issue and for rattle #4. Only problem is that I have finals next week and I am not sure that I am going to be ok without transportation. Might have to wait for a week and a half to take it in. ARGH.
let them drive it and see the problem for themselves
book appointment after ur midterm/finals
or ask for a loaner...
ive had the same problem...most likely you'll have to get the radio replaced...definitely disappointing...
http://www.acura-tsx.com/forums/show...center+console
use search to find more related threads...
I just got that problem fixed. Seems to be more prevalent as more TSX's are on the road. Dealer told me that there is a independent dimmer switch for the radio/ac/clock and that component shorted out. No way to fix the problem just requires replacement of the entire center console. It will probably take a while to get a new radio since they were on back-order and took 1 1/2 weeks to get mine. But they fixed it and gave me a loaner ('04 TL btw) and now it works fine.
Take the car in!
2-4 weeks to replace with a refurb since there is a "critical shortage". said that they had 6 TSX's with the same problem... and that it seems like they all broke exactly at the same time.
BoricuaTL
04-08-2016 01:08 PM
