Steering Noise/Vibration
I recently replaced my steering rack with a brand new Maval 93154MN. After install, everything looks good. No leaks. No bubbles in the reservoir. I've also done the air bleeding procedure per Maval manual.
But I have this strange noise. It's more of a noise from a vibration and it seems to be the rack itself vibrating. It's not the pump. With the hood open, I've tested it. There no noise or vibrations from the pump. And the noise from the vibration can really only be heard from the inside of the car.
In this video... you'll hear it when I turn the wheel to the right. It just comes on for about a second:
https://www.flickr.com/gp/runningwit...eam/57Rzv2252phttps://www.flickr.com/gp/runningwit...eam/57Rzv2252p
Has anyone experienced this before with a brand new rack?
You used OEM Acura/Honda PS fluid to flush the system as recommended by the Maval TSB attached?
siuwan
1G TSX Problems & Fixes
Jul 18, 2004 10:01 AM
