Squeaky Button
Old Jan 4, 2006 | 07:30 AM
wesleyl524's Avatar
Squeaky Button
I couldn't find a thread on this...
The "Dual" button next to the navi screen squeaks like a a rustry hinge when I press it.
Does anyone know how to fix this? The car is only 3 months old, and I rarely have a passenger to even make use of the dual climate feature, so the button is seldom pressed.
Thanks!
Old Jan 4, 2006 | 09:06 AM
HoRRo's Avatar
iVTEC no koe
If it's only 3 months old, bring it back to the dealer.
Old Jan 4, 2006 | 09:37 AM
wesleyl524's Avatar
True, but the closest acura dealer and the one i bought mine from is over 100 miles away. i'd rather handle this one on my own if possible, than waste an entire day, especially if the fix involves WD-40
Old Jan 4, 2006 | 09:39 AM
HoRRo's Avatar
iVTEC no koe
Dunno how friendly WD-40 would be on the HVAC/Navi system.....I will pray for you.
Old Jan 4, 2006 | 11:08 AM
S14 n Tsx's Avatar
mmmmmm....
you are joking right???!?
Old Jan 4, 2006 | 12:45 PM
Colin's Avatar
If I was going to try anything myself, I'd use graphite.....
Old Jan 4, 2006 | 12:59 PM
jlukja's Avatar
I get a similar "squeaking" on the down-volume button on the steering wheel controls.
Old Jan 4, 2006 | 03:29 PM
wesleyl524's Avatar
I'm not going to use WD-40 on it.
Although after buying my first house, I leanred that it does fix nearly everything.
I'm sure there something that can be done. Otherwise, perhaps it will just work itself out over time of being pushed.
Old Jan 4, 2006 | 03:35 PM
GIBSON6594's Avatar
My Garage
Protects silver from tarnishing
Cleans and lubricates guitar strings
Gets oil spots off concrete driveways
Gives floors that 'just-waxed' sheen without making it slippery
Keeps flies off cows
Stops "Dual" button next to Navi from squeeking
Restores and cleans chalkboards
Removes lipstick stains
Loosens stubborn zippers
Untangles jewelry chains
Removes stains from stainless steel sinks
Removes dirt and grime from the barbecue grill
Keeps ceramic/terra cotta garden pots from oxidizing
Removes tomato stains from clothing
Keeps glass shower doors free of water spots
Camouflages scratches in ceramic and marble floors
Keeps scissors working smoothly
Lubricates noisy door hinges on vehicles and doors in homes
Gives children's play gym slide a shine for a super fast slide
Lubricates gear shift and mower deck lever for "ease of handling" on riding mowers
Rids rocking chairs and swings of squeaky noises
Lubricates tracks in sticking home windows and makes them easier to open
Spraying an umbrella stem makes it easier to open and close
Restores and cleans padded leather dashboards and vinyl bumpers
Restores and cleans roof racks on vehicles
Lubricates and stops squeaks in electric fans
Lubricates wheel sprockets on tricycles, wagons and bicycles for easy handling
Lubricates fan belts on washers and dryers and keeps them running smoothly
Keeps rust from forming on saws and saw blades, and other tools
Removes splattered grease on stove
Keeps bathroom mirror from fogging
Lubricates prosthetic limbs
Keeps pigeons off the balcony (they hate the smell)
Removes all traces of duct tape
I have even heard of folks spraying it on their arms, hands, and knees to relieve arthritis pain.
Florida's favorite use was cleans and removes love bugs from grills and bumpers
Bug guts will eat away the finish on your car if not removed quickly! Use WD-40!
WD-40 protects the Statue of Liberty from the elements.
WD-40 attracts fish. Spray a LITTLE on live bait or lures-you'll be catching the big one in no time. It's a lot cheaper than the chemical attractants that are made for just that purpose. Keep in mind though, using some chemical laced baits or lures for fishing are not allowed in some states.
Use it for fire ant bites. It takes the sting away immediately, and stops the itch.
WD-40 is great for removing crayon from walls. Spray on the mark and wipe with a clean rag.
Also, if you've discovered that your teenage daughter has washed and dried a tube of lipstick with a load of laundry saturate the lipstick spots with WD-40 and re wash. Presto! Lipstick is gone!
If you sprayed WD-40 on the distributor cap, it would displace the moisture and allow the car to start. (If I knew what a distributor cap was, it might help)
WD-40, long known for its ability to remove leftover tape gunk (sticky label tape), is also a lovely perfume and air freshener! (Joking)
Sprayed liberally on every hinge in the house, it leaves that distinctive clean fresh scent for up to two days!
It removes black scuff marks from the kitchen floor! Use WD-40 for nasty tar and scuff marks on flooring. It doesn't seem to harm the finish and you won't have to scrub nearly as hard to get them off. Just remember to open some windows if you have a lot of marks.
Disclaimer: Gibson6594 added the bold text as a gag. WD-40 may or may not stop the dual button from squeeking.
Old Jan 4, 2006 | 03:49 PM
cusetsx's Avatar
05 ABP NONAV BONE STOCK
Do you plan on doing all the scheduled maintenance yourself and/or locally? If not then just wait until your next scheduled maintenance in which you'd be driving the 100 miles anyway.
Old Jan 4, 2006 | 04:05 PM
gsclifton's Avatar
ABP TSX
I would wait until the next dealer visit unless the squeak is going to cause a "postal" incident or road rage.
Otherwise you might try some graphite as suggested or a minute amount of Pro Honda Silicone spray on a q-tip.
You also might swing by a Honda dealer if they are closer.
Old Jan 4, 2006 | 06:06 PM
Colin's Avatar
... and here I thought it was the clear bra from the other thread that did this...
Gibby, I hope you did a 'cut and paste' for your list.... that was WAAAAY too much work otherwise!
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
hashbrown
Sep 29, 2015 12:13 PM
dirleton
Sep 29, 2015 08:26 AM
thegipper
Sep 28, 2015 01:01 PM
