Should I get first oil change?
Thriller
I got the car in August and only have 1800 miles on it...yeah yeah...I don't really use the car cus I live in NYC. I know about the special factory oil but as I'm approaching the spring I would think I should change it soon.
What are the pros & cons in my case? Should I wait until 3700 as the dealer recommended? Michael Wan...I need your advice buddy!
http://www.acura-tsx.com/forums/showthread.php?t=24744
Originally Posted by Normal Maintenance Schedule
For normal driving conditions
The "normal" schedule is fine for most drivers, even if they occasionally drive in severe conditions.
10,000 mi/16,000 km Scheduled Maintenance
Replace engine oil.
Rotate tires (follow pattern on page 276 of your owner's manual).
Check engine oil and coolant at each fuel stop.
Check and adjust valve clearance, cold engine, only if noisy.
Replace engine oil.
Thriller
Originally Posted by jlukja
1. Leave factory oil in until 3700 but the oil will be 1 year old.
2. Change the oil now and lose any factory oil conditioning/sealing benefits.
Which of the 2 should I pick?
Make a determination whether you fall under the "severe" or "normal" useage category. If you fall under "severe" then change it after 6 months, if under "normal" then change it after 1 year. And, BTW, not sure why your dealer picked 3700 for recommending the change. It should be either 5000 or 10000 miles, depending on type of useage.
Or, to say it a different way, If you drive under normal conditions the first oil change, per Honda's recommendation, is at 1 year or 10,000 miles, whichever comes first. For severe driving, 6 months or 5,000 miles, again whichever comes first.
I'm sure you'll get a variety of answers to your question. Anywhere from "Do it at 500mi to get the metal particles out" to "wait until 10K miles like the manual says". You'll have to decide who to listen to, and what to do.
I waited until 5000 miles, which for me took about 8 months, before I did the first oil change. I didn't switch to Mobil1 synthetic until my second oil change at 10,000 mi. I don't plan to do my third change until either 20K miles or 1 year after the 10K change. Please don't take what I did as the "correct" way. Is simply the intervals that I chose.
Too early IMO but I have a feeling you won't listen anyway so do whatever you feel like. Won't really do any harm at all.
Pretty sure this particular topic has been discussed to absolute death on this busy forum.
Thriller
Thanks J...the dealer's recommendation of 3700 threw me off as it did not take into account Normal or Severe driving. So I guess as a Normal driver I'll ignore his recommendation and do my change in August (1 year). I'll probably just make 3600 miles by then...perfect!
Huck...I'm listening I am!
lol that's probably true.....
I live in Austin also...and i am pretty sure i fall into severe condition
which synthetic oil should i use?
i remember there's a thread use something with hi molypoly or something XD
Shit I just saw this thread.
You can change it out earlier...but really don't need to....Just wait 3000-5000 miles. If you're going to do it early, just run Havoline 5w30 conventional oil, which will have lots of Moly in it. Or use whatever oil the dealer used and add a bottle of Valvoline Synpower Oil Treatment to it, which is really just Moly and AW additives.
mada51589
05-03-2022 08:54 PM
HydrasunGQ
09-14-2015 10:14 PM
