Shifting into Reverse (MT)
Old 12-24-2004, 01:11 AM
lukatmyshu's Avatar
How do you guys feel about the position of Reverse ... I prefer it next to 1st gear BUT requiring that you press in the gear-shift when you shift. Here's why ... When going from 5-6 the stick is going to move a little to the left ... so you have to move it a little bit more to the right to compensate. However it you move it to much and go down .... you're going 60 MPH and end up in reverse. Does the TSX MT have any sort of protection to prevent you from doing that?
Old 12-24-2004, 01:29 AM
Punk Rocker
majin ssj eric's Avatar
There is a mechanical lockout that prevents shifting into reverse when moving forward (you'll just get a lot of grinding until you come to your senses and stop trying to shift into reverse). This is standard in all manual transmissions that I know of.
Old 12-24-2004, 02:45 AM
biker's Avatar
The answer to this was just posted two days ago the site.
Old 12-24-2004, 03:06 AM
Master Graphic Artist
PixelHarmony's Avatar
I think all cars would that have the reverse next to the 5-6 gear, I know the TSX does because I tried it out once. Just like how you can't shift into R in any 5spd. I too personally like the reverse gear next to second gear, but oh well... we can't have everything we want.
Old 12-24-2004, 03:51 PM
Powered by Honda's Avatar
I like R where it is on the TSX....I dont like it near 1st and 2nd like the germans do it.
Old 12-24-2004, 04:42 PM
MemRheins's Avatar
Only time ill ever be able to say this so... Thats the Reason why you guys should of gotten a 5AT
Old 12-24-2004, 08:23 PM
NickR's Avatar
Well, I've had both (next to 5-6 in the TSX and next to 1-2 in a VW Jetta Turbo). I do like it next to 1-2 just because it seems like anytime you need reverse, you'll need 1st right away and having it right there makes it easier and a little quicker. I dont mind the TSX, but with 6 gears, it seems like reverse is a long way over there.
Old 12-25-2004, 01:05 AM
Can't wait to drive
Arcticcl9's Avatar
Having R to the right of 5-6 is fine for me.. Technically you're going straight down when shifting from 5-6 if you're shifting properly (just that your shift knob is bent to the right). Also, R not only has lockout, but it's spaced further out than 5 and 6 are. It's impossible to shift to R in normal circumstances..unless you have no idea what you're doing
Old 12-29-2004, 01:56 PM
ClutchPerformer's Avatar
Originally Posted by lukatmyshu
....I prefer it next to 1st gear BUT requiring that you press in the gear-shift when you shift....
Ugh. That drives me nuts. It's the only thing I don't like about German cars.
Old 12-29-2004, 02:08 PM
NickR's Avatar
it did take a little while to get used to pushing down then right for R in the VW.
The funniest was my wife's first drive in the car. She wanted to take it to work so I left before her. She couldn't figure out how to back out of the garage so she had to leave it in neutral and push back with her foot hanging out the door. It took her about another month before she asked to drive it again. it was great!
Old 12-29-2004, 02:25 PM
Old 12-29-2004, 07:02 PM
TAC Moderat0r
fastfreddy's Avatar
Read the Owner's Manual in FULL.
Old 12-29-2004, 07:08 PM
Subie Tech
JeffTSX's Avatar
Old 12-30-2004, 01:03 AM
I'm just funkin around...
SmokinHaze's Avatar
Old 12-30-2004, 11:06 AM
n00b
vwong's Avatar
Same here, but my experiences with BMW's are all in auto-x. In some courses, I had to shift to 3rd, then downshift to 2nd (some even required to downshift to 1st). Most of the time, I ended up putting the damn shift level in the reverse slot (not into reverse though). I don't know if the newer BMW's have any improvement on this, but the ones I drove (E30 M3, E36 325, and E36 M3) were all like that. I guess it would take me some more time to get used to. I still prefer the pattern in the TSX. Works great.
Old 12-30-2004, 11:07 AM
n00b
vwong's Avatar
Classic!
SidhuSaaB
05-30-2020 12:40 AM
navtool.com
Sponsored Sales & Group Buys
87
01-23-2016 01:25 PM
Popee
12-20-2015 12:08 AM
Hines57
09-24-2015 01:58 PM
STC
09-23-2015 04:36 PM
Quick Reply: Shifting into Reverse (MT)
