Service at Dealer says Timing Belt
I have heard great things about the dealer I bought from but why the heck do they tell me I have a timing belt on my 05 TSX AT???? Do you think they just want to make money?? If that is the case I will call and confront them
2010 TL SH-AWD
Timing chain last longer but once it is old and stretched out, be ready for the infamous timing chain rattle. TO me timing belt is soo much better, even though it needs to be change at 100k its worth it than having your engine sound like a sewing machine.
So even if you change the timing chain, it will cost more than it would for a regular belt change. Because it involves more work to remove the whole front part of the chain cover, as the chain uses motor oil for lube. Almost like part of an internal.
I dont know who said timing chain does NOT need to be replace, but Ford, Nissan and many other manufactor uses them and they are known to break, snap and jump gears when they get old. Especially on a high revving motor, I wouldnt risk it.
Timing chains are generally good for the life of the engine.
160k miles on my Nissan GA16DE w/timing chain and still running strong.
Originally Posted by virus7
i think people refer to the timing chain not needing replacement, because you wait till it wears out rather than having to replace it on a proactive basis. I had over 145k miles on my nissan altima with no timing chain issues.
True but if your going to go through all the trouble just to change the tensioner?
Same deal with timing belts.
Moderator Alumnus
Originally Posted by JTso
The timing chain is not even on the maintenance schedule. Chain > belt. Btw, the oil pump is also driven by a chain off the crank.
All they`ll do is inspect it once in a while, that`s it.
Booya
Originally Posted by psteng19
3 words: timing chain tensioner.
2010 TL SH-AWD
You don't change tensioners, you adjust it.
It is right that chain lasts, but its the related component that wears out. Timing gears is the other, they're only metal that heats up, cool down, and wear . Nuff said, to each maintain they're own vehicle. I been through so many Ka24de and sr20det's .
Originally Posted by dipkat
I have the SR20DE engine in my Nissan 200SX-SER with 125K miles and the timing chain is still good.
At 125 k miles---- lets hope it's still good tomorrow.
Matell
I have a friend who recently had the timing belt snap on his Mitsubishi Lancer. End result......broken rocker arm, bent valve, and damaged pistion=stuffed engine.
Timing belts? No thanks.
C'mon, man! Row yer own.
Yeah, I'm with you. Whoever it was who thought to combine the timing belt, the water pump (which is prone to siezing and frying the belt) and the interference engine was a repair-work-profits genius. I had that happen on a '94 Camry (except, luckily, it was non-interference). Twelve hours later I had the water pump and timing belt replaced (d.i.y. -- what else?). Ridiculous.
I much prefer a chain. It lasts longer -- with a tensioner and regular oil changes, ostensibly forever -- and it's WAY less likely to break or shear a tooth and do damage. Not foolproof, it's mechanical, but much better system.
I thought timing belts were invented to make engines quieter (and maybe increase dealer repair profits?). I don't mind at all if my engine sounds like it's mechanical. It is.
Zonian22
11-14-2015 01:20 PM
asahrts
09-04-2015 05:55 PM
