Road force vs Standard Balancing-is it worth it?
Old Mar 2, 2013 | 06:10 PM
gardel's Avatar
Question Road force vs Standard Balancing-is it worth it?
How much difference there is between these two? What's the cost for road force balance the wheels?
Old Mar 2, 2013 | 06:59 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
RFB...totally worth it if you run UHP tires on your car. dynamic balance does not load your tire as if your car was sitting on the tires themselves.
RFB can also determine if there is excessive lateral forces that may potentially cause a pull while driving even if the alignment is set correctly. if these lateral forces are well outside of acceptable tolerances, then the tire is deemed bad and you will not be able to balance the tire. the lateral forces can also be taken into account and "balanced" with the other 3 wheels and tires and positioned accordingly at each corner to eliminate pulling due to lateral forces from the tire. google "hunter road force balance" and you will see what i mean.
my dealer charges $115 for RFB at all 4 corners (which is no different than mount and balance costs at other places ($20-30) per wheel. find a shop that has the hunter RFB machine more than likely they use the machine often. most dealers also have the machine.
i don't like paying twice for balancing my wheels and tires. i'm willing to pay a little extra to have it done correctly the first time and without the shop damaging my rims.
Old Mar 2, 2013 | 07:36 PM
nj2pa2nc's Avatar
it's a car-drive it
The dealer I use in pa uses the hunter road force machine. Whenever I had my tires rotated they balanced them. I think that help extend the life of my tires. The most I paid was $29.00 which was for rotating and balancing the 4 tires.
Old Mar 2, 2013 | 08:15 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
^^they probably didn't balance them...they might have checked them. a tire rotation costs $30.
Old Mar 2, 2013 | 08:22 PM
nj2pa2nc's Avatar
it's a car-drive it
I was shown how they balance my tires with the hunter machine. Yes that price included both rotation and balance.
Old Mar 2, 2013 | 08:30 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
dont' expect to get that price when you get new tires installed. it just means they checked it. doesn't mean they actually had to work and add wts to your wheels. just sayin'. unless the car has some weird vibration or pulling not fixed by an alignment, there really isn't a need to balance the wheels and tires each time you rotate the tires.
Old Mar 2, 2013 | 08:39 PM
nj2pa2nc's Avatar
it's a car-drive it
dont' expect to get that price when you get new tires installed. it just means they checked it. doesn't mean they actually had to work and add wts to your wheels. j sayin'. unless the car has some weird vibration or pulling not fixed by an alignment, there really isn't a need to balance the wheels and tires each time you rotate the tires.
Had new tires put on the end of June. The previous tires had almost 70k miles on them. We had those tires balanced each time they were rotated. Makes:: the tires last longer IMO. The OEM Michelin tires lasted 74k+ miles. Probably don't have to balance the tires if the car is rarely driven.
Old Mar 3, 2013 | 04:57 AM
Simba91102's Avatar
Old Guy
Meow! Catfight!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
knight rider
Mar 4, 2016 08:59 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
iesu3423
Sep 29, 2015 08:04 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
