Replacement AUX Jack for '08 TSX?
Hey all,
I've been having issues with the AUX jack in m my '08 TSX. It's a typical issue where if you accidentally jiggle or twist the AUX cable a little bit, it messes with the sound, so I'm looking to purchase a new replacement (the one in the center console).
Does anyone know where I can get one without breaking the bank? From a quick search, it seems like the part number I'm looking for is 39112-SEC-A01. I found that part on here on AcuraPartsWarehouse for $70, but that seems a bit steep to me. Or who knows, maybe I'm wrong.
Anyways, would love to get some input. Thanks!
I think your best bet would be used on ebay or find a local junkyard and pull the piece yourself. alternately, you can spend a little extra and get a bluetooth module that has an aux port, such as the usaspec BT45-HON for the vehicle. that would give you bluetooth audio as well. Works flawlessly for me.
https://acurazine.com/forums/3g-tl-p...repair-987763/
Can you try to see if this can fix your issue?
Admittedly not the same car but it can be of help..
The problem is that if I jiggle or turn the 3.5 jack that's plugged into the car end, sometimes the sound will cut out in a speaker, etc. Stuff like that. Which leads me to thinking that the jack piece just needs to be replaced.
Not sure if I'm missing something else or if that makes sense.
rman402
12-23-2008 02:08 PM
