replace rear brakes with aftermarket but oem still on the front?
Is there any issue with replacing your rear brakes with aftermarket pads while keeping oem pads on the front? My rear pads are ready to be replaced, and I want to upgrade to hawk pads and possibly new rotors in the back. Would I run into any problems upgrading the rear brakes but waiting to replace the front oem brakes? My fronts have a good amount of life on them still...
You'll be fine. It'll just "look" funny if you have slotted rotors (should you choose to go that route) in the rear, with OEM rotors up front.
The car has a 70/30 F/R brake bias, so most of your braking is taken care of with your front brakes. Just make sure to match them to the rear when it's time.
Whenever you replace your brake pads, you should resurface the rotors. However, there is a HIGH chance that your turned rotors will warp. It's happened to many people, including me.
mada51589
Jan 9, 2025 04:40 PM
